Date/Time: Tue, 10 Nov 2026 19:11:17 +0000
Denali historical data length
View Count: 358
| [2026-08-10 14:45:43] |
| caldie67 - Posts: 10 |
Hi. I need quality intraday historical data, including price and volume. I would only use this historical data for backtesting, NOT for real-time trading. I need many years... at least 6 years. Does Denali meet these requirements? Or should I turn to IQFeed, which is much more expensive? A precise and complete answer, please. |
| [2026-08-11 01:25:17] |
| Sierra_Chart Engineering - Posts: 25407 |
Yes, Sierra Chart has the data that you require. So what exchange do you need this data for?
| [2026-08-11 10:18:30] |
To get started, I need futures data on the Nasdaq 100 and S&P 500. Remember, I only need historical intraday trading and volume. How much would it cost, including the SierraChart platform?
| [2026-08-12 06:45:16] |
The Sierra Chart Historical Data Service provided with Service Package 3 provides what you need: Sierra Chart Historical Data Service For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-12 06:45:44
