Date/Time: Tue, 10 Nov 2026 19:11:18 +0000
saved study collections don't appear in the control bar customization menu
View Count: 255
| [2026-08-10 12:39:28] |
| User290454 - Posts: 9 |
I have created 3 study collections. They are all stored in the correct place (in the data folder - C/SierraChart/Data), all 3 appear under the analysis menu, and all 3 work when applied to a chart as they should. However, I can't apply any of the study collections as customized buttons on control bar. I have added study collections 1, 2 ad 3 (SC1,2,3) to a control bar, but when depressing the customize button, none of my created study collections appear in the available list (which is empty) for assignment. What can i do to resolve the problem?
| [2026-08-10 14:09:37] |
| Sierra_Chart Engineering - Posts: 25407 |
What version of Sierra Chart is this happening with? We are not seeing any problems with this. Can you provide a screenshot, of what you see when you press the Customize button. Instructions to attach: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-10 14:10:21
| [2026-08-10 15:35:16] |
I use version 2930. screenshot for what is see when customize button is selected, has been attached.
| [2026-08-10 15:40:58] |
Left click in the Value column on the row that says Study Collection Name. You might have to left click twice and then you will get a list box with the names.
| [2026-08-10 16:56:25] |
Thanks for the help
