Date/Time: Fri, 13 Nov 2026 05:35:30 +0000
replay mode does not continue after pause
View Count: 238
| [2026-08-08 08:44:04] |
| ldepadey - Posts: 73 |
Hi, replay mode does not seem it continue after pause has been hit, it just freezes and i have to stop the whole replay and hit play again in order to start it. Is there any known fix for this? thanks |
| [2026-08-09 02:15:48] |
| Sierra_Chart Engineering - Posts: 25419 |
Make sure the chart is active, by clicking anywhere on it before using the Replay control panel. Try increasing the replay speed: Replaying Charts: Speed When you notice this condition, stop the replay. Do you then notice the chart loads all the way up to the current time when stopping the replay? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-09 02:16:32
