Date/Time: Tue, 10 Nov 2026 05:18:37 +0000
Help with Setting Quote Board Default Fields
View Count: 252
| [2026-08-07 23:20:25] |
| User275839 - Posts: 73 |
Hi - I'm using SC 2933 on Win 11/AMD. I would like to set default fields for new quote board dialogs for working with symbol lists. However, when I try to set my desired field configuration using Global Settings > Quote Spreadsheet Settings per the online documentation, those settings are not applied to new quote boards. Further, the list of fields shown in the actual quote board window's Settings > Set Fields dialog is different from those shown in the above mentioned Global Settings > Quote Spreadsheet Settings dialog. E.g. "Trade Direction" is shown in the Quote Board fields list, but not in the Quote Spreadsheet Settings list. How can I set up a default Quote Board window layout and have it stick, using the fields shown in the Quote Board settings options? Date Time Of Last Edit: 2026-08-08 05:43:50
| [2026-08-09 00:41:24] |
| Sierra_Chart Engineering - Posts: 25406 |
What you need to do is to edit the Quote Board fields as explained here: Getting Quotes: Setting Fields to Display And then configure them as you want and press the Save As Defaults button on that window. This will then apply to any new Quote Boards opened thereafter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-09 00:43:24
