Date/Time: Mon, 02 Nov 2026 19:33:35 +0000
[User Discussion] - deviding multiple contracts target into more limit orders
View Count: 2185
| [2014-11-04 07:44:59] |
| User30743 - Posts: 399 |
hi, i dont know how to put an attach order into market when i trade with more then one contract the way i describe bellow i enter the market with lets say 2 contracts, both stop and target are at the same price and with OCO relations http://prntscr.com/52vhy5, now when the market moves i want to devide the two-contracts target into two separated limit orders, but i dont know how. - i do it by setting new quantity - http://prntscr.com/52vih6 - ok, but when the market fills this first target (limit order), there is no second target (limit order) i could move with (there is only stop, which is ok) - http://prntscr.com/52vhrp so i need to close the position not with limit order but with market order, which is not what i want to do. so, could you please tell me how to put THE SECOND TARGET (limit order) into the market, when i devide the multiple contract target? |
| [2014-11-06 01:15:38] |
You have to cancel those Attached Orders and resubmit new ones using two separate target orders. You can configure multiple Trade Window configurations which can be quickly selected: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Here are instructions to submit Attached Orders separately: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-06 01:16:48
| [2014-11-18 11:59:52] |
well, the problem is, that i would like to quickly change the pre defined contracts.. lets say i have defined: 1 contract (stoploss 10 tick, profit target 14 tick) under the number 1 at the TRADE WINDOW - http://prntscr.com/57l5xt 2 contracts (stoploss 10 tick, first profit target 10, second profit target 20) under the number 2 at the TRADE WINDOW http://prntscr.com/57l792 and now i want to change them according to the strenge of a signal in the market with a simple click of a mouse at the right corner of my orderflow chart - http://prntscr.com/57l8fa but it is not possible - because when it was once set to 2 contracts (with two separated targets as described above) and i want to enter the market with only one contract (as described above), it tells me a mistake message that the order quantity for a parrent order is too small and i need to reset it - http://prntscr.com/57l8si so the question is HOW TO QUICKLY CHANGE THESE PREDEFINED SETUPS? Date Time Of Last Edit: 2014-11-18 12:04:01
