Date/Time: Tue, 10 Nov 2026 05:18:36 +0000
Volume profile tool stops updating real time
View Count: 326
| [2026-08-07 17:43:46] |
| OrderFlow - Posts: 34 |
When first applied on a chart it updates for a minute or 2 then stops updating real time...any reason?
| [2026-08-07 18:06:05] |
The Volume Profile tool, to clarify
| [2026-08-07 18:24:53] |
| John - SC Support - Posts: 48480 |
The Drawn Volume Profile lets you define the start and end times for where a Volume Profile will be drawn. If you set the end-point of this tool in the forward projection area, then the profile will update until it gets to that end-time. If you are wanting a profile that continually updates, then you would need to use the Volume by Price study instead of the Drawn Volume Profile tool. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-07 19:02:40] |
Got it, thank you...I like the fact I can snap it and start it anywhere I want so I'll continue to use it but I'll scroll the chart over a bit so i can extend the end time.
