Date/Time: Tue, 10 Nov 2026 05:18:37 +0000
Question
View Count: 267
| [2026-08-07 12:59:48] |
| User437588 - Posts: 92 |
Hello, I'm trying to change the Draw Volume Profile because it's assigned to a hotkey. Unfortunately, despite several attempts, the same setting keeps appearing. How exactly can I change the DVP and assign this configuration to the corresponding hotkey? Thank you very much for your help. |
| [2026-08-07 13:32:30] |
| John - SC Support - Posts: 48480 |
We are not certain of exactly the question you are asking. Refer to the following for how the Drawn Volume by Price configuration gets setup: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-07 13:56:07] |
I want a different configuration that I’ve saved to open via the hotkey. The same one always appears. See the chart!
| [2026-08-07 14:01:48] |
Then you need to change the configuration that is setup for that hotkey. The instructions for how a configuration is setup for the Drawn Volume Profile are here: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
