Date/Time: Tue, 10 Nov 2026 05:18:35 +0000
Build Custom Studies DLL
View Count: 547
| [2026-08-07 11:39:07] |
| Marek F - Posts: 254 |
If i build any custom studies by option "Build With Visual C++ - Release", then Build Output is: -- Starting build of Custom Studies Source files: Studies.cpp. -- 13:31:55
C:\Windows\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat" C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" amd64 cl : Command line warning D9002 : ignoring unknown option '/std:c++17' Studies.cpp c:\sierrachart\acs_source\scdatetime.h(1423): error C2143: syntax error: missing ',' before ')' c:\sierrachart\acs_source\scdatetime.h(1423): error C2059: syntax error: ')' -- End of Build -- 13:31:57 If i build the same study by option "Remote Build - Standard", then Build Output is: -- Starting remote build of Custom Studies Source files: Studies.cpp. 64-bit -- 13:37:05
Allow time for the server to compile the files and build the DLL. Server: https://build.sierrachart.com The remote build is complete. The build succeeded. The compiler response is empty. Writing file to: C:\SierraChart\Data\Studies_64.dll -- End of Build -- 13:37:15 |
| [2026-08-07 21:57:16] |
| Sierra_Chart Engineering - Posts: 25406 |
First we have heard of this and we do not see this. Maybe the compiler you are running is out of date but anyway we will remove that line. It is not essential.
| [2026-08-07 23:29:54] |
The solution is to update the Visual C++ compiler on your system. You can do that from here: https://visualstudio.microsoft.com/visual-cpp-build-tools/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-08 18:56:44] |
The issue was on my end and was resolved by updating the compiler C++. Thank you |
