Date/Time: Tue, 10 Nov 2026 05:18:39 +0000
Child Windows State - Bug
View Count: 292
[2026-08-07 11:05:01]
Marek F - Posts: 254
I updated from an old, no longer supported version of Sierra Chart to the latest 2933.
1. I have two instances of Sierra Chart running on separate monitors.
2. I have over a dozen charts (child windows) in the chartbook, which are identical in both instances. Every child window is in a Restored state.
3. If I select a child window from the list in the CW menu list to switch another child window, then this selected child window has opend in a Maximize state. (BUG)
4. If I select a Restored command, then this child window returned in the Restored state, but disappear another child Window. (BUG)
5. These bugs only appear on the instance on the second monitor.
[2026-08-07 21:46:37]
Sierra_Chart Engineering - Posts: 25406
Check how this setting is set:
Global Settings >> General Settings >> Windows >> Main Menu >> CW Menu Selection Action for MDI Chart Windows : {"Activate", "Restore", "Maximize", "Hide Current, Maximize Selected"}
Set it the way that you want. Probably Activate.
