Date/Time: Tue, 10 Nov 2026 05:18:35 +0000
Is there any way to prevent Market Depth heatmap from getting blown out?
View Count: 303
[2026-08-06 15:06:09]
warpigs - Posts: 83
Every day on NQ some joker comes in and drops 1000 lot order on the book then pulls it, effectively blowing out any contrast on the heatmap. Is there anything I can do about this via the settings? Nothing I change has any effect, but I'm guessing there might be a combination of settings I'm not aware of that could help.
[2026-08-06 15:22:18]
John - SC Support - Posts: 48480
If you know that the value is somewhere around 1000, then set the following in the Market Depth Historical Graph:
- Value Type for Highest Quantity for Coloring: Actual Value
- Highest Quantity for Coloring: 900 (or some other number that will cut off a high item like that)
[2026-08-06 15:44:46]
warpigs - Posts: 83
I was trying that but it wasn’t working, it’s working now though, thanks!
