Date/Time: Sat, 07 Nov 2026 05:21:55 +0000
NUMBERS BAR (calculated values Delta Sum)
View Count: 348
[2026-08-04 21:25:50]
blt - Posts: 229
to: SIERRA CHART TEAM
Be so kind and evaluate following:
When I form Study Subgraph Difference between (SG43-SG44)(diagonal) in Numbers Bars Calculated Values and compare it with (SG4-SG5)(not diagonal) I am getting THE SAME VALUE !!!
That is WRONG !!! unless I read it wrong and I apologize for that
Testing this is very simple: just compare Sum Deltas of horizontal and diagonal reading-->NO DIFFERENCE; WRONG !!!
Please evaluate my findings and feel free to curse me for my incompetence
Thank you
Leonardo
[2026-08-04 21:59:09]
John - SC Support - Posts: 48459
It is not wrong. Why do you state that it is wrong? Work through the math and you will see that it is correct.
Just look at one bar and add up the numbers and you will see it.
Date Time Of Last Edit: 2026-08-04 21:59:23
[2026-08-04 22:30:48]
blt - Posts: 229
Thank you John
I was WRONG (didn't calculate top/bottom zeros)
