Date/Time: Sat, 07 Nov 2026 05:21:55 +0000
Binance Crypto sc.Tick size and VAP changes
View Count: 306
[2026-08-04 14:32:27]
stiasny - Posts: 25
Hi, Over the weekend all my studies utilizing sc.Tick and VAP functions started drawing in straight lines for VAP and super Thick lines where thickness depend on the sc.Tick value. After having a look sc.Tick for XRP increased to 0.1, and every Bar has exactly one VAP level, at 1.10. Is this something which can be dealt with by my studies or if not, do you plan to fix it on your side?
Best, Aleš
[2026-08-05 20:01:24]
Sierra_Chart Engineering - Posts: 25393
We changed the default Tick Size for Binance symbols to .1 from a smaller value to avoid severe performance problems when loading Volume at Price data.
What you need to do is to go into Chart >> Chart Settings and set this to No:
Chart Settings: Auto Set from Data Feed (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
And adjust to the Tick Size to what you want:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
