Date/Time: Wed, 04 Nov 2026 05:15:01 +0000
MDI scroll bar adjustment
View Count: 305
| [2026-08-03 02:49:46] |
| User163966 - Posts: 8 |
Release 2933 / MDI Window Virtual Space Percentage is not reflected in scroll bar thumb size. MDI Window Virtual Space Percentage is set to 200 but the button is not reflecting that value. In previous releases the thumb would be roughly half the height of the track and 1 click would move window from top to bottom Am i missing a setting adjustment? |
| [2026-08-03 03:49:44] |
| Sierra_Chart Engineering - Posts: 25370 |
Nothing has changed with this functionality. And the button, you are referring to has never been designed to be like you describe.
| [2026-08-03 11:03:54] |
could someone please take a minute to try and understand the issue I am reporting and help resolve this situatio? Perhaps a screen shot would be helpful? Is there a prior release that can be installed which has the Window Virtual Space scroll bar responding to the window percentage as was the case before the required update yesterday? Date Time Of Last Edit: 2026-08-03 13:28:55
