Date/Time: Tue, 03 Nov 2026 19:21:45 +0000
Single Prints
View Count: 436
| [2026-08-02 21:02:28] |
| MGuest - Posts: 7 |
I am given to understand that it is not possible to export Single Prints directly using a dll created by a cpp file. What is your guidance on how to determine a Single Print has been formed using a cpp file / dll? |
| [2026-08-02 23:30:00] |
| Sierra_Chart Engineering - Posts: 25364 |
Are you referring to Singles determined by the TPO Profile Chart study?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-02 23:30:10
| [2026-08-03 12:50:28] |
| MGuest - Posts: 7 |
yes
| [2026-08-03 12:51:06] |
| MGuest - Posts: 7 |
File attached
| [2026-08-04 00:57:27] |
There is not a way to directly get TPO Profile Singles. Here is the documented logic of them: Time Price Opportunity (TPO) Profile Charts: Extend Singles You can then use this function to obtain the number of TPO profile blocks/letters per price level and then determine which price level is a single within a specific profile: ACSIL Interface Members - Functions: sc.GetVolumeAtPriceDataForStudyProfile() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-04 00:59:07
