Date/Time: Wed, 04 Nov 2026 05:15:06 +0000
DOM Heatmap too much zoomed in?
View Count: 332
| [2026-08-02 13:39:23] |
| User959918 - Posts: 1 |
Hello, I would like to know how do I get a good oveview of the heatmap without losing the DOM size? This is how it looks when I chose for "Reset bar size/spacing/scale": https://www.sierrachart.com/image.php?Image=1785677078755.png now I can read the DOM perfectly. But I want the heatmap to look like this: https://www.sierrachart.com/image.php?Image=1785677311832.png but if I do that I lose the readability of the DOM.. Im using NQ what I did to (make it better) is to adjust the real time to 0.1 but then my heatmap looked (messed up) also im trying to keep the price as possible to the original[CME/tradingview..] https://www.sierrachart.com/image.php?Image=1785677583434.png any ideas? I have found out that switching from ES to NQ is a world of difference Thank you |
| [2026-08-03 15:42:34] |
| John - SC Support - Posts: 48413 |
You are trying to view the same information in two different ways. Fortunately, the ability to combine the data is controlled separately for those two things. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) Market Depth Historical Graph: Combine Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
