Date/Time: Wed, 04 Nov 2026 05:15:06 +0000
This is just a suggestion that would be extremely helpful
View Count: 305
| [2026-08-01 20:25:27] |
| User195597 - Posts: 7 |
Volume filtering of all of the DOM's VBP Studies columns is controlled by centralized "Volume Filter Settings" in the DOM's Chart Data Limiting, which makes it impossible to get same column side by side with a different filtering options on the same DOM, and pushes me to have multiple DOMs for that reason, which is totally unnecessary since it's eating resources and slows the system down... Would be nice, for instance, to be able on the same DOM to have total vol POC by Chart Data Limiting and "Bid minus Ask" delta filtered by Exclude <= 50 and so on. It would be extremely helpful!!! Proposal: 1. The logic is already in your system with Chart Data Limiting; 2. Add an option in VBP's setting for Custom Data Limiting Volume Filter as "Yes" or "NO"; 3. Default is "No", which takes Chart Data Limiting settings as it does now; 4. If "Yes" = True than be able to customize additional "Exclude <=" for that only VBP and ignore global Chart Data limiting. It'd be really great to have that! Thank you for listening, J |
| [2026-08-01 23:07:10] |
| Sierra_Chart Engineering - Posts: 25370 |
This is definitively not possible and it is nothing that would ever be considered and it is impossible to implement anyway due to the design. There will be 0% consideration of this ever.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-01 23:07:23
