Date/Time: Mon, 02 Nov 2026 15:46:29 +0000
2 ot of three Flex Rhenko charts NOT UPDATING
View Count: 305
| [2026-07-31 18:21:29] |
| User360283 - Posts: 538 |
HELP PLEASEASA[ THANKS |
| [2026-07-31 19:22:46] |
| John - SC Support - Posts: 48385 |
What are the symbols of these charts? What exactly is occurring in the charts that are not updating? When is the date-time of the most current bar visible in those charts? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-04 12:19:06] |
3 Monitor One Flx Rhenko on each Rehnkos are12-11-1 25-24-1 and 40-39-1 The 40-39-1 stopped updating Bit is now working OK <ust be Vampires LOL |
| [2026-08-04 14:09:25] |
| Sierra_Chart Engineering - Posts: 25352 |
When you notice the problem, within that same chart, change the bar period to 1 minute per bar and see if that resolves the problem. So we can better understand the cause.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-04 15:19:01
