Date/Time: Wed, 04 Nov 2026 11:12:15 +0000
Single stock futures not listed
View Count: 363
| [2026-07-31 11:45:24] |
| UserAR - Posts: 102 |
I followed the instructions to 'update from server', disconnected then reconnected and I still don't see the symbols listed. I am using version 2933. Can you confirm they are listed? Thanks
| [2026-07-31 15:13:05] |
| John - SC Support - Posts: 48413 |
These are not yet setup for services other than "SC Data" and "Teton CME Routing". Therefore, in order to get the data at this time, you would need to install a second Sierra Chart and leave the "Current Selected Service" as "SC Data". Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-31 15:48:46] |
Ok, that explains it. Thank you
