Date/Time: Sun, 01 Nov 2026 04:42:23 +0000
Required Update for Teton Order Routing - Need Version 2800 or Higher
View Count: 401
| [2026-07-29 22:35:07] |
| Sierra_Chart Engineering - Posts: 25338 |
A mandatory/required update will be required for Teton Order Routing usage from June 20, 2026. You will need to be running version 2800 or higher. For instructions to update, refer to: Software Download: Fast Update We did not require this update on June 20, but we will this coming weekend, August 1, 2026. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
