Date/Time: Sun, 08 Nov 2026 21:26:17 +0000
User Email Questions
View Count: 1355
[2014-11-03 17:36:14]
I have been trying to find and locate in the Online FAQ etc
do i need the 20 or 27 dollar package for access to the cumulative delta indicators .. tick up/down and bid/ask volume
ie is this part of standard or additional features ;
Beyond the trial i initially require :
cumulative delta for bid/ask volume (where available eg for futures) and up/down tick volume for others forex/cfds & including futures
Reversal bar type
later i may consider the Volume profile and number bars which i understand are part of the premium package,
So on this basis would standard features suffice for me at this time (after trial).
Also i currently have futures broker but want to know which and if data wise brokers/data service provide futures and forex data combined.
Or is it likely i will require to run two instances of sierra on machine - one for futures data and another for forex/cfds?
Sierra Chart Support
[2014-11-05 04:38:37]
We recommend using service package 3 but since we do not know what Data or Trading service you will be using Sierra Chart with, we cannot give you a definite answer on this. This is why we recommend service package 3.
For the necessary data for the studies that you want to use, you need the Sierra Chart Historical Data Service.
Based upon what you require, we recommend using Sierra Chart service package 3.
We recommend running two copies of Sierra Chart. One for futures and one for Forex. Refer to this page:
Using Multiple Data and Trading Services at the Same Time
