Date/Time: Tue, 27 Oct 2026 18:33:24 +0000
Question on Features
View Count: 243
| [2026-07-28 14:50:36] |
| User518468 - Posts: 20 |
I have to tell you what I would like (and I'm being spoiled here) I would like the ability to set different pulling/stacking level quantities on different instruments without opening a new instance. The possibility to have [Made by Sierra] the so called “momentum tails” in the recent bid/ask volume column or in a new dedicated column. And other little details that, to be honest, don't even come to mind right now. |
| [2026-07-28 15:55:12] |
| John - SC Support - Posts: 48342 |
The ability to set the Pulling/Stacking levels on a per chart basis has been in the system for at least 6 months now, and maybe as long as a year. Refer to the following: Chart Settings: Maximum Market Depth Pulling Stacking Levels (Chart >> Chart Settings >> Display >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
