Date/Time: Tue, 27 Oct 2026 18:33:21 +0000
profit management
View Count: 214
[2026-07-28 11:35:06]
Robert Wojczak - Posts: 178
I am trying to set loss limits in the global profit management tab .i say "profit management system is disabled" how do I get it to work... thank you
[2026-07-28 13:28:12]
John - SC Support - Posts: 48342
There are two sides (controls) to the "Global Profit/Loss Management" window, one for Profit and one for Loss. You do not need to use them both, you can use them separately.
So if you have only setup the loss side (on the right) then the profit side will show that it is not setup and will state "Profit management is disabled."
If you do want to use the Profit side, then you need to enable the option at the top for "Flatten Positions when Profit Rules Met". Refer to the following:
[2026-07-28 13:44:29]
thank you
