Date/Time: Thu, 29 Oct 2026 03:04:28 +0000
Question about agreements for data feeds
View Count: 265
| [2026-07-27 18:04:02] |
| User518468 - Posts: 20 |
Hey guys; I’m trying to purchase “US equities consolidated tape” data; I completed the three agreements shown in the screenshot yesterday, but as you can see, their status is still completely blank (neither accepted nor rejected). From what I understand, this process is usually fairly quick, though I might be wrong about that! I just wanted to double check if everything went through correctly or if you need anything else from my end. Thanks for your help! |
| [2026-07-27 19:54:04] |
| John - SC Support - Posts: 48363 |
It typically is fairly quick that the agreements are reviewed and the response posted, but it can take as long as 24 hours and longer if these are done on a weekend, as you may have to wait for Monday. We see that these have been taken care of for your account, so you can go ahead and activate the exchanges you want at this time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
