Date/Time: Mon, 26 Oct 2026 03:12:35 +0000
[User Discussion] - INTERACTIVE SCALE RANGE
View Count: 206
| [2026-07-26 16:21:16] |
| User722905 - Posts: 10 |
THE KEY STROKES FOR INTERACTIVE SCALE RANGE ARE NOT VISIBLE (OR NOT PRESENT) ON VERSION 2930. PLEASE INSTALL KEY STROKES FOR INTERACTIVE SCALE RANGE!! THE KEYS FOR INTERACTIVE MOVE ARE PRESENT AND FUNCTIONAL.
| [2026-07-27 14:45:24] |
| Sierra_Chart Engineering - Posts: 25272 |
We see no problem with this. When using the Control key, the opposite state is invoked as explained here: Chart Scale and Scale Adjusting: Inverting the Scale Mode And we set up keyboard shortcuts for Interactive Scale Range and Interactive Scale Move and changed between them with the keyboard without any problems. By default there are no keyboard shortcuts for these. To set these up, refer to: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
