Date/Time: Mon, 26 Oct 2026 03:13:40 +0000
Cumulative Delta
View Count: 299
| [2026-07-25 10:18:36] |
| User997794 - Posts: 3 |
Im in replay but the cumulative Delta indicator does not show the day replaying only up to the day before is there a reason for this? Thank You |
| [2026-07-27 15:07:39] |
| John - SC Support - Posts: 48317 |
There is no reason there should be an issue with this. First, make sure the Cumulative Delta Bars - Volume is setup for the chart before you start the replay. If there is anything wrong with the Cumulative Delta prior to strting the replay, then we would first need to look into that. Then, when you start the replay, you should have the Cumulative Delta Bars - Volume up to where the replay starts from already showing. If this is not what you are seeing, then please get us an image of your chart when you have this problem. And also get us an image of the chart showing the same time location prior to starting the replay (we want to see the Cumulative Delta Bars - Volume without the replay for comparison). Follow these instructions to get us images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
