Date/Time: Fri, 23 Oct 2026 15:05:41 +0000
[Sticky] [Locked] - Updated: Information about CME Single Futures Support
View Count: 3622
[2026-07-25 04:21:20]
Sierra_Chart Engineering - Posts: 25249
Technical information about the new CME single stock futures is here:
https://cmegroupclientsite.atlassian.net/wiki/spaces/EPICSANDBOX/pages/1347387394/Single+Stock+Futures
Sierra Chart, is working on adding support for these. Market data will be recorded as of this coming Sunday evening on July 26, 2026. Symbol Settings for the different services will be provided this coming week.
There is a significant amount of setup and configuration that we need to do for them.
Support for trading these on Teton order routing will come as soon as we can. We do not want to give a definite time but trading them might be available in a week or two. Not very long. There are many technical details we need to check including security identifiers, and margin to make sure all of that is going to work as expected.
[2026-07-29 06:16:51]
Market data for CME single stock futures is now available.
It is available when using Teton order routing or "SC Data". It will be available with other services shortly.
We do not yet have all of the symbols listed. We just listed Nvidia and Apple. We will get all of them by early next week.
First step:
Next step:
From the main menu, select File >> Find Symbol >> Single Stock Futures-CME (expand this). You will see the symbols listed.
You can also manually type in a symbol as well following the same format shown.
Trading is not yet supported.
Date Time Of Last Edit: 2026-07-29 06:17:52
[2026-07-29 22:32:43]
All of the CME single stock futures symbols are now listed.
You will find them listed in:
At this point, no trading should be attempted for the symbols and clearing firms should not allow them. By default they are not allowed. Until we do testing, and make sure they work properly, do not trade them.
Date Time Of Last Edit: 2026-07-29 23:39:21
[2026-08-06 20:24:35]
We have tested trading in the symbol:
XNVDAU26_FUT_CME
Margin data is being obtained and is correct.
This is the security ID information for it in New Release (not production):
FIX Message #1
When we tried to trade the symbol on the CME New Release environment, we did get a rejection but that is not really so relevant to the test:
2026-08-06 14:33:02.795 | Teton CME Routing (Order reject). Info: CME (Rejected). Text: Order price is outside bands 'Ask of 19900.00 violates Low Band 20559.00 using Delta .00, CrvBnd equals 20759.00'. SecurityID=42008273. Operator=IDENTIFIER_2. Internal Order ID: 92737. Service Order ID: 9054. Symbol: XNVDAU26_FUT_CME. Account: Test102 *
As of Sunday evening, August 9, clearing firms can enable trading, if they choose to do so. We do not observe any problems which are of concern. Trading has to be enabled per individual single stock futures.
FIX Messages:
FIX Message #1:
35=d|5799=00000000|980=A|779=20260805172202000926|1682=18|1180=324|1300=62|462=5|207=XCME|
1151=SNVDA|6937=XNVDA|55=XNVDAU6|48=42008273|22=8|167=FUT|461=FFIXSX|200=202609|15=USD|
1142=F|562=1|1140=3000|969=1.000000000|9787=0.010000000|996=IPNT|1147=10.000000000|1150=22050.000000000|731=00000010|
5796=20260805|1148=1.000000000|1143=200.000000000|1146=0.100000000|9779=N|37513=1004918869138141635|864=2|865=5|1145=20260624213000000000|
865=7|1145=20260918200000000000|1141=1|1022=GBX|264=10|870=1|871=24|872=00000000000001000010000001001011|1234=0|
5791=22|5792=272|
  • 35 (MsgType): d
  • 5799 : 00000000
  • 980 : A
  • 779 (LastUpdateTime): 20260805172202000926
  • 1682 : 18
  • 1180 : 324
  • 1300 : 62
  • 462 (UnderlyingProduct): 5
  • 207 (SecurityExchange): XCME
  • 1151 : SNVDA
  • 6937 : XNVDA
  • 55 (Symbol): XNVDAU6
  • 48 (SecurityID): 42008273
  • 22 (SecurityIDSource): 8
  • 167 (SecurityType): FUT
  • 461 (CFICode): FFIXSX
  • 200 (MaturityMonthYear): 202609
  • 15 (Currency): USD
  • 1142 : F
  • 562 (MinTradeVol): 1
  • 1140 : 3000
  • 969 : 1.000000000
  • 9787 : 0.010000000
  • 996 : IPNT
  • 1147 : 10.000000000
  • 1150 : 22050.000000000
  • 731 (SettlPriceType): 00000010
  • 5796 : 20260805
  • 1148 : 1.000000000
  • 1143 : 200.000000000
  • 1146 : 0.100000000
  • 9779 : N
  • 37513 : 1004918869138141635
  • 864 (NoEvents): 2
  • 865 (EventType): 7
  • 1145 : 20260918200000000000
  • 1141 : 1
  • 1022 : GBX
  • 264 (MarketDepth): 10
  • 870 (NoInstrAttrib): 1
  • 871 (InstrAttribType): 24
  • 872 (InstrAttribValue): 00000000000001000010000001001011
  • 1234 : 0
  • 5791 : 22
  • 5792 : 272
Date Time Of Last Edit: 2026-08-11 21:34:48
