Date/Time: Mon, 26 Oct 2026 03:12:35 +0000
unable to re-load data for MESU6.CME
View Count: 281
[2026-07-24 09:40:45]
User526075 - Posts: 4
hi team i am missing data from june to current date, the data is not loading
the data loads for ES but not the micros
unsure why if i could get some help, i have deleted and reload and still doesnt work
see below
2026-07-24 07:30:01.680 | Trade activity files set size: 190
2026-07-24 07:30:01.732 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-07-24 07:30:01.879 | Reading Internal Order ID file.
2026-07-24 07:30:01.909 | Reading Trade Orders file.
2026-07-24 07:30:01.916 | Reading Trade Positions file.
2026-07-24 07:30:01.922 | Reading Trade Account Data files.
2026-07-24 07:30:01.945 | Software version: 2930 64-bit
2026-07-24 07:30:01.945 | Primary Thread ID: 6384
2026-07-24 07:30:01.945 | Usage end date: 2026-08-20
2026-07-24 07:30:01.945 | Enabled for: Advanced Features 2.
2026-07-24 07:30:01.945 | Enabled for: Sierra Chart Historical Data Service.
2026-07-24 07:30:01.945 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-07-24 07:30:01.945 | Enabled for: Delayed Denali Exchange Data Feed.
2026-07-24 07:30:01.945 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-07-24 07:30:01.945 | Current selected Data/Trading service: Rithmic Direct - DTC
2026-07-24 07:30:01.945 | Custom symbol settings values: enabled
2026-07-24 07:30:01.945 | Chart Update Interval: 400
2026-07-24 07:30:01.945 | Intraday Data Storage Time Unit: 1
2026-07-24 07:30:01.945 | Time Zone: +00:00:00 (UTC+00)
2026-07-24 07:30:01.945 | 2026-07-24 07:30:01 Local computer time in UTC
2026-07-24 07:30:01.945 | 2026-07-24 07:30:01 Local computer time in SC Time Zone
2026-07-24 07:30:01.945 | 2026-07-24 07:29:43 Server time in UTC
2026-07-24 07:30:01.945 | Local computer UTC time and Server UTC time difference: 13 seconds.
2026-07-24 07:30:01.945 | Notice: Your computer's clock is off by 13 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'.
2026-07-24 07:30:01.945 | Program path: C:\SierraChart\
2026-07-24 07:30:01.945 | Data Files path: C:\SierraChart\Data\
2026-07-24 07:30:01.948 | OS Version Number: 10.0
2026-07-24 07:30:01.948 | Locale Setting: C
2026-07-24 07:30:01.948 | Crash reporter started: true
2026-07-24 07:30:02.023 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2026-07-24 07:30:02.024 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2026-07-24 07:30:02.025 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2026-07-24 07:30:02.025 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2026-07-24 07:30:02.027 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:02.284 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-07-24 07:30:02.285 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-07-24 07:30:02.831 | Received 5 login tokens.
2026-07-24 07:30:03.191 | Symbol settings MD5 received. Request ID: 1.
2026-07-24 07:30:03.191 | Symbol settings are up-to-date for rithmic_v2.trading.
2026-07-24 07:30:04.560 | Requested user files to download.
2026-07-24 07:30:04.582 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-07-24 07:30:04.585 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-07-24 07:30:04.840 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2026-07-24 07:30:04.841 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:05.085 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2026-07-24 07:30:05.086 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2026-07-24 07:30:05.754 | There are no user files to download.
2026-07-24 07:30:06.575 |
2026-07-24 07:30:06.596 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2026-07-24 07:30:06.596 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2026-07-24 07:30:06.602 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2026-07-24 07:30:06.921 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-07-24 07:30:06.921 | DTC Client socket (1) | New receive buffer size: 0
2026-07-24 07:30:06.921 | DTC Client socket (1) | Connecting to IP: 184.105.22.231.
2026-07-24 07:30:07.147 | Rithmic Direct - DTC | Network connection to server complete.
2026-07-24 07:30:07.147 | Rithmic Direct - DTC | Starting socket receive thread.
2026-07-24 07:30:07.151 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-07-24 07:30:07.173 | Rithmic Direct - DTC | Sending logon request message.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Received logon response.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Server Name: .
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Successfully connected.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Trading is supported.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | OCO Orders supported.
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-07-24 07:30:08.172 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-07-24 07:30:08.178 | Rithmic Direct - DTC | Connection to server complete.
2026-07-24 07:30:08.261 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-07-24 07:30:08.267 | Subscribing to symbol for symbol alert. ZNM4.CBOT
2026-07-24 07:30:08.332 | Using symbol data fast lookup vector
2026-07-24 07:30:08.400 | Rithmic Direct - DTC | Starting real-time market data updates for: ZNM4.CBOT. ID: 1 Service code: rithmic.trading
2026-07-24 07:30:08.418 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50531
2026-07-24 07:30:08.418 | Rithmic Direct - DTC | Requesting security definition data for: ZNM4.CBOT. ID: 1
2026-07-24 07:30:08.418 | Subscribing to symbol for symbol alert. CLG4.NYMEX
2026-07-24 07:30:08.420 | Rithmic Direct - DTC | Starting real-time market data updates for: CLG4.NYMEX. ID: 2 Service code: rithmic.trading
2026-07-24 07:30:08.420 | Rithmic Direct - DTC | Requesting security definition data for: CLG4.NYMEX. ID: 2
2026-07-24 07:30:08.465 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees.
2026-07-24 07:30:08.470 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-07-24 07:30:08.471 | DTC Client socket (2) | New receive buffer size: 0
2026-07-24 07:30:08.471 | DTC Client socket (2) | Connecting to IP: 184.105.22.231.
2026-07-24 07:30:08.751 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2026-07-24 07:30:08.751 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2026-07-24 07:30:08.751 | Rithmic Direct - DTC (Data) | Using fixed encoding of Binary
2026-07-24 07:30:08.751 | Rithmic Direct - DTC (Data) | Sending logon request message.
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Received logon response.
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Server Name: .
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Successfully connected.
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Trading is not supported.
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLG4.NYMEX
2026-07-24 07:30:09.428 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ZNM4.CBOT
2026-07-24 07:30:09.818 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2026-07-24 07:30:09.981 | XAUUSD 1 Min #1 | Reloading chart.
2026-07-24 07:30:10.350 | XAUUSD Daily #2 | Reloading chart.
2026-07-24 07:30:10.509 | US30 1 Min #3 | Reloading chart.
2026-07-24 07:30:10.638 | USOil 1 Min #4 | Reloading chart.
2026-07-24 07:30:10.790 | ESU6.CME 1 Min #5 | Reloading chart.
2026-07-24 07:30:11.065 | SPX500 Daily #6 | Reloading chart.
2026-07-24 07:30:12.451 | EURUSD Daily #7 | Reloading chart.
2026-07-24 07:30:13.042 | EURUSD 5 Min #8 | Reloading chart.
2026-07-24 07:30:14.665 | ESU6.CME #9 | Reloading chart.
2026-07-24 07:30:15.498 | ESU6.CME 1 Min #10 | Reloading chart.
2026-07-24 07:30:23.525 | AAPL-NQTV 5 Min #11 | Reloading chart.
2026-07-24 07:30:24.241 | USOil 1 Min #4 | Chart data loading complete.
2026-07-24 07:30:24.254 | SPX500 Daily #6 | Chart data loading complete.
2026-07-24 07:30:24.271 | EURUSD Daily #7 | Chart data loading complete.
2026-07-24 07:30:24.286 | XAUUSD Daily #2 | Chart data loading complete.
2026-07-24 07:30:24.300 | US30 1 Min #3 | Chart data loading complete.
2026-07-24 07:30:24.345 | ESU6.CME 1 Min #5 | Chart data loading complete.
2026-07-24 07:30:24.358 | ESU6.CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 2026-07-23 16:15:00
2026-07-24 07:30:24.361 | ESU6.CME 1 Min #10 | Chart data loading complete.
2026-07-24 07:30:24.494 | ESU6.CME #9 | Chart data loading complete.
2026-07-24 07:30:24.584 | EURUSD 5 Min #8 | Chart data loading complete.
2026-07-24 07:30:24.599 | XAUUSD 1 Min #1 | Chart data loading complete.
2026-07-24 07:30:25.610 | AAPL-NQTV 5 Min #11 | Chart data loading complete.
2026-07-24 07:30:25.769 | Using Bid/Ask average for last trade price for XAUUSD
2026-07-24 07:30:25.786 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 3 Service code: fxcm
2026-07-24 07:30:25.799 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2026-07-24 07:30:25.801 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 3
2026-07-24 07:30:25.804 | Starting DelayedDownloadMonitoringTimer
2026-07-24 07:30:25.804 | Starting HDTimeoutTimer
2026-07-24 07:30:25.806 | Added historical Intraday data request for XAUUSD to the queue.
2026-07-24 07:30:25.806 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'.
2026-07-24 07:30:25.818 | Triggering next historical data download in queue.
2026-07-24 07:30:25.820 | Delaying start of download for XAUUSD.
2026-07-24 07:30:26.239 | Using Bid/Ask average for last trade price for US30
2026-07-24 07:30:26.239 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm
2026-07-24 07:30:26.239 | SC Data with Depth | Requesting security definition data for: US30. ID: 4
2026-07-24 07:30:26.241 | Added historical Intraday data request for US30 to the queue.
2026-07-24 07:30:26.241 | Intraday data recording state for symbol US30 is set to download 'Pending'.
2026-07-24 07:30:26.241 | Triggering next historical data download in queue.
2026-07-24 07:30:26.261 | Using Bid/Ask average for last trade price for USOil
2026-07-24 07:30:26.262 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 5 Service code: fxcm
2026-07-24 07:30:26.262 | SC Data with Depth | Requesting security definition data for: USOil. ID: 5
2026-07-24 07:30:26.262 | Added historical Intraday data request for USOil to the queue.
2026-07-24 07:30:26.262 | Intraday data recording state for symbol USOil is set to download 'Pending'.
2026-07-24 07:30:26.274 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 6 Service code: rithmic.trading
2026-07-24 07:30:26.280 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 6
2026-07-24 07:30:26.281 | Added historical Intraday data request for ESU6.CME to the queue.
2026-07-24 07:30:26.281 | Intraday data recording state for symbol ESU6.CME is set to download 'Pending'.
2026-07-24 07:30:26.286 | Using Bid/Ask average for last trade price for SPX500
2026-07-24 07:30:26.286 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 7 Service code: fxcm
2026-07-24 07:30:26.286 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 7
2026-07-24 07:30:26.287 | Using Bid/Ask average for last trade price for EURUSD
2026-07-24 07:30:26.288 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 8 Service code: fxcm
2026-07-24 07:30:26.288 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 8
2026-07-24 07:30:26.289 | Added historical Intraday data request for EURUSD to the queue.
2026-07-24 07:30:26.289 | Intraday data recording state for symbol EURUSD is set to download 'Pending'.
2026-07-24 07:30:26.376 | ESU6.CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:30:26.400 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data
2026-07-24 07:30:26.401 | Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 9 Service code: nasdaq_exchange.data
2026-07-24 07:30:26.403 | Delayed Data Feed | Connecting to the server ds30.sierracharts.com. Port 10043
2026-07-24 07:30:26.403 | Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 9
2026-07-24 07:30:26.403 | Added historical Intraday data request for AAPL-NQTV to the queue.
2026-07-24 07:30:26.403 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'.
2026-07-24 07:30:26.403 | Triggering next historical data download in queue.
2026-07-24 07:30:26.681 | DTC Client socket (4) | Creating socket.
2026-07-24 07:30:26.869 | DTC Client socket (4) | New receive buffer size: 0
2026-07-24 07:30:26.869 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2026-07-24 07:30:26.873 | DTC Client socket (5) | Creating socket.
2026-07-24 07:30:26.873 | DTC Client socket (5) | New receive buffer size: 0
2026-07-24 07:30:26.873 | DTC Client socket (5) | Connecting to IP: 67.214.125.11.
2026-07-24 07:30:26.874 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Creating socket. Using TLS 1.2.
2026-07-24 07:30:26.874 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | New receive buffer size: 0
2026-07-24 07:30:26.874 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Connecting to IP: 216.66.0.130.
2026-07-24 07:30:27.125 | SC Data with Depth | Network connection to server complete.
2026-07-24 07:30:27.125 | SC Data with Depth | Starting socket receive thread.
2026-07-24 07:30:27.126 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2026-07-24 07:30:27.138 | Delayed Data Feed | Network connection to server complete.
2026-07-24 07:30:27.138 | Delayed Data Feed | Starting socket receive thread.
2026-07-24 07:30:27.139 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2026-07-24 07:30:27.599 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2026-07-24 07:30:27.679 | Delayed Data Feed | Sending logon request message.
2026-07-24 07:30:27.679 | SC Data with Depth | Setting DTC encoding to Binary VLS
2026-07-24 07:30:27.679 | SC Data with Depth | Sending logon request message.
2026-07-24 07:30:28.062 | SC Data with Depth | Received logon response.
2026-07-24 07:30:28.062 | SC Data with Depth | Server Name: SC Realtime Server.
2026-07-24 07:30:28.062 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2026-07-24 07:30:28.062 | SC Data with Depth | Successfully connected.
2026-07-24 07:30:28.062 | SC Data with Depth | Trading is not supported.
2026-07-24 07:30:28.062 | SC Data with Depth | MarketDepthIsSupported: 1
2026-07-24 07:30:28.135 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD
2026-07-24 07:30:28.135 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2026-07-24 07:30:28.135 | SC Data with Depth | Restarting real-time data updates for symbol: US30
2026-07-24 07:30:28.135 | SC Data with Depth | Restarting real-time data updates for symbol: USOil
2026-07-24 07:30:28.135 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD
2026-07-24 07:30:28.222 | Delayed Data Feed | Received logon response.
2026-07-24 07:30:28.222 | Delayed Data Feed | Server Name: SC Realtime Server.
2026-07-24 07:30:28.222 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2026-07-24 07:30:28.222 | Delayed Data Feed | Successfully connected.
2026-07-24 07:30:28.222 | Delayed Data Feed | Trading is not supported.
2026-07-24 07:30:28.222 | Delayed Data Feed | MarketDepthIsSupported: 1
2026-07-24 07:30:28.222 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV
2026-07-24 07:30:28.981 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18
2026-07-24 07:30:28.981 | SC Data with Depth | Received security definition for symbol EURUSD
2026-07-24 07:30:29.067 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2026-07-24 07:30:29.067 | SC Data with Depth | Received security definition for symbol SPX500
2026-07-24 07:30:29.067 | SC Data with Depth | Setting external service identifier for symbol US30 to 58
2026-07-24 07:30:29.067 | SC Data with Depth | Received security definition for symbol US30
2026-07-24 07:30:29.067 | SC Data with Depth | Setting external service identifier for symbol USOil to 60
2026-07-24 07:30:29.067 | SC Data with Depth | Received security definition for symbol USOil
2026-07-24 07:30:29.067 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62
2026-07-24 07:30:29.067 | SC Data with Depth | Received security definition for symbol XAUUSD
2026-07-24 07:30:29.067 | Delayed Data Feed | Setting external service identifier for symbol AAPL-NQTV to 41
2026-07-24 07:30:29.067 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV
2026-07-24 07:30:29.884 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-07-24 07:30:29.939 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-07-24 07:30:30.216 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | CloseSocket call.
2026-07-24 07:30:30.218 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:30.454 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Socket gracefully closed by remote side.
2026-07-24 07:30:30.455 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (6) | Closed.
2026-07-24 07:30:34.869 | HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm
2026-07-24 07:30:34.871 | HD Request # 1 | Download start date-time: 2026-07-24 06:53:47.000000. File last date-time: 2026-07-24 06:53:47.000000
2026-07-24 07:30:34.879 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149
2026-07-24 07:30:34.947 | Socket (3) | Creating socket.
2026-07-24 07:30:34.947 | Socket (3) | New receive buffer size: 0
2026-07-24 07:30:34.947 | Socket (3) | Connecting to IP: 69.39.70.241.
2026-07-24 07:30:35.478 | HD Request # 1 | Setting DTC encoding to Binary VLS
2026-07-24 07:30:35.478 | HD Request # 1 | Sending historical data logon request message.
2026-07-24 07:30:35.756 | HD Request # 1 | Requesting Intraday data. Start date-time: 2026-07-24 06:53:47. Record interval: 1. Symbol: XAUUSD
2026-07-24 07:30:36.305 | HD Request # 1 | Decompressing data.
2026-07-24 07:30:36.312 | HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2026-07-24 06:53:47.017000
2026-07-24 07:30:36.557 | Socket (3) | CloseSocket call.
2026-07-24 07:30:36.557 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:36.559 | Historical data download thread signaled to stop.
2026-07-24 07:30:36.867 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:30:36.868 | Socket (3) | Closed.
2026-07-24 07:30:37.548 | HD Request # 1 | Timestamp of first Intraday data file record written: 2026-07-24 06:53:47.017000.
2026-07-24 07:30:37.549 | HD Request # 1 | Received 2039 Intraday data records from 2026-07-24 06:53:47.017000 to 2026-07-24 07:30:34.215000 (36.8 minutes. Delay: 3.3 seconds) and wrote 2039 records for XAUUSD
2026-07-24 07:30:37.551 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:30:34.215000
2026-07-24 07:30:37.552 | Added 4 Time and Sales records to Intraday data file for XAUUSD after download.
2026-07-24 07:30:37.557 | HD Request # 1 | Completion time: 3s.
2026-07-24 07:30:37.557 | HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1
2026-07-24 07:30:37.557 | Removing historical data download ID 1.
2026-07-24 07:30:37.558 | Real-time Intraday chart data file updates started for XAUUSD
2026-07-24 07:30:37.576 | Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 6384
2026-07-24 07:30:37.576 | Intraday chart data file opened for XAUUSD
2026-07-24 07:30:37.576 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:37.577 |
2026-07-24 07:30:37.577 | Triggering next historical data download in queue.
2026-07-24 07:30:37.587 | HD Request # 2 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm
2026-07-24 07:30:37.589 | HD Request # 2 | Download start date-time: 2026-07-24 06:53:45.000000. File last date-time: 2026-07-24 06:53:45.000000
2026-07-24 07:30:37.589 | HD Request # 2 | Using server: ds4.sierracharts.com port 10150
2026-07-24 07:30:38.249 | Socket (3) | Creating socket.
2026-07-24 07:30:38.250 | Socket (3) | New receive buffer size: 0
2026-07-24 07:30:38.250 | Socket (3) | Connecting to IP: 64.152.155.113.
2026-07-24 07:30:38.730 | HD Request # 2 | Setting DTC encoding to Binary VLS
2026-07-24 07:30:38.730 | HD Request # 2 | Sending historical data logon request message.
2026-07-24 07:30:38.981 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-07-24 06:53:45. Record interval: 1. Symbol: US30
2026-07-24 07:30:39.217 | HD Request # 2 | Decompressing data.
2026-07-24 07:30:39.701 | HD Request # 2 | Receiving Intraday data for US30 starting at 2026-07-24 06:53:45.161000
2026-07-24 07:30:39.703 | Socket (3) | CloseSocket call.
2026-07-24 07:30:39.703 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:39.704 | Historical data download thread signaled to stop.
2026-07-24 07:30:39.705 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-07-24 06:53:45.161000.
2026-07-24 07:30:39.706 | HD Request # 2 | Received 1808 Intraday data records from 2026-07-24 06:53:45.161000 to 2026-07-24 07:30:39.040000 (36.9 minutes. Delay: 0.7 seconds) and wrote 1808 records for US30
2026-07-24 07:30:39.707 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:30:39.040000
2026-07-24 07:30:39.707 | Added 1 Time and Sales records to Intraday data file for US30 after download.
2026-07-24 07:30:39.708 | HD Request # 2 | Completion time: 2s.
2026-07-24 07:30:39.708 | HD Request # 2 | Intraday data download complete for US30. Unique request ID: 2
2026-07-24 07:30:39.708 | Removing historical data download ID 2.
2026-07-24 07:30:39.708 | Real-time Intraday chart data file updates started for US30
2026-07-24 07:30:39.708 | Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 6384
2026-07-24 07:30:39.709 | Intraday chart data file opened for US30
2026-07-24 07:30:39.709 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:39.709 | Triggering next historical data download in queue.
2026-07-24 07:30:39.709 | HD Request # 3 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm
2026-07-24 07:30:39.711 | HD Request # 3 | Download start date-time: 2026-07-24 06:53:47.000000. File last date-time: 2026-07-24 06:53:47.000000
2026-07-24 07:30:39.711 | HD Request # 3 | Using server: ds12.sierracharts.com port 10149
2026-07-24 07:30:39.712 | Socket (6) | Creating socket.
2026-07-24 07:30:39.712 | Socket (6) | New receive buffer size: 0
2026-07-24 07:30:39.712 | Socket (6) | Connecting to IP: 69.39.70.241.
2026-07-24 07:30:39.942 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:30:39.942 | Socket (3) | Closed.
2026-07-24 07:30:40.258 | HD Request # 3 | Setting DTC encoding to Binary VLS
2026-07-24 07:30:40.258 | HD Request # 3 | Sending historical data logon request message.
2026-07-24 07:30:40.528 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-07-24 06:53:47. Record interval: 1. Symbol: USOil
2026-07-24 07:30:40.785 | HD Request # 3 | Decompressing data.
2026-07-24 07:30:41.321 | HD Request # 3 | Receiving Intraday data for USOil starting at 2026-07-24 06:53:47.011000
2026-07-24 07:30:41.324 | Socket (6) | CloseSocket call.
2026-07-24 07:30:41.324 | Socket (6) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:41.325 | Historical data download thread signaled to stop.
2026-07-24 07:30:41.360 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-07-24 06:53:47.011000.
2026-07-24 07:30:41.360 | HD Request # 3 | Received 1693 Intraday data records from 2026-07-24 06:53:47.011000 to 2026-07-24 07:30:42.085000 (36.9 minutes. Delay: -0.7 seconds) and wrote 1693 records for USOil
2026-07-24 07:30:41.368 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:30:42.085000
2026-07-24 07:30:41.368 | HD Request # 3 | Completion time: 2s.
2026-07-24 07:30:41.368 | HD Request # 3 | Intraday data download complete for USOil. Unique request ID: 3
2026-07-24 07:30:41.368 | Removing historical data download ID 3.
2026-07-24 07:30:41.368 | Real-time Intraday chart data file updates started for USOil
2026-07-24 07:30:41.374 | Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 6384
2026-07-24 07:30:41.374 | Intraday chart data file opened for USOil
2026-07-24 07:30:41.374 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:41.375 | Triggering next historical data download in queue.
2026-07-24 07:30:41.375 | HD Request # 4 | Downloading Intraday chart data for ESU6.CME to the file ESU6.CME.scid. Service: rithmic.trading
2026-07-24 07:30:41.377 | HD Request # 4 | Download start date-time: 2026-07-24 06:53:45.000000. File last date-time: 2026-07-24 06:53:45.000000
2026-07-24 07:30:41.377 | HD Request # 4 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:30:41.377 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:30:41.380 | Socket (3) | New receive buffer size: 0
2026-07-24 07:30:41.380 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:30:41.584 | Socket (6) | Socket gracefully closed by remote side.
2026-07-24 07:30:41.584 | Socket (6) | Closed.
2026-07-24 07:30:41.601 | HD Request # 4 | Sending historical data logon request message.
2026-07-24 07:30:42.291 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-07-24 06:53:45. Record interval: 1. Symbol: ESU6.CME
2026-07-24 07:30:42.528 | HD Request # 4 | Receiving Intraday data for ESU6.CME starting at 2026-07-24 06:53:46.000000
2026-07-24 07:30:43.417 | Socket (3) | CloseSocket call.
2026-07-24 07:30:43.418 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:43.418 | Historical data download thread signaled to stop.
2026-07-24 07:30:43.420 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-07-24 06:53:46.000000.
2026-07-24 07:30:43.420 | HD Request # 4 | Received 1417 Intraday data records from 2026-07-24 06:53:46.000000 to 2026-07-24 07:30:44.000000 (37.0 minutes. Delay: -0.6 seconds) and wrote 1417 records for ESU6.CME
2026-07-24 07:30:43.421 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:30:44.000000
2026-07-24 07:30:43.421 | HD Request # 4 | Completion time: 2s.
2026-07-24 07:30:43.421 | HD Request # 4 | Intraday data download complete for ESU6.CME. Unique request ID: 4
2026-07-24 07:30:43.421 | Removing historical data download ID 4.
2026-07-24 07:30:43.421 | Real-time Intraday chart data file updates started for ESU6.CME
2026-07-24 07:30:43.422 | Opened cached Intraday file: C:\SierraChart\Data\ESU6.CME.scid. Thread ID: 6384
2026-07-24 07:30:43.422 | Intraday chart data file opened for ESU6.CME
2026-07-24 07:30:43.422 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:43.422 | Triggering next historical data download in queue.
2026-07-24 07:30:43.422 | HD Request # 5 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm
2026-07-24 07:30:43.427 | HD Request # 5 | Download start date-time: 2026-07-24 06:53:47.000000. File last date-time: 2026-07-24 06:53:47.000000
2026-07-24 07:30:43.428 | HD Request # 5 | Using server: ds4.sierracharts.com port 10149
2026-07-24 07:30:43.428 | Socket (6) | Creating socket.
2026-07-24 07:30:43.428 | Socket (6) | New receive buffer size: 0
2026-07-24 07:30:43.428 | Socket (6) | Connecting to IP: 64.152.155.113.
2026-07-24 07:30:43.635 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:30:43.636 | Socket (3) | Closed.
2026-07-24 07:30:43.920 | HD Request # 5 | Setting DTC encoding to Binary VLS
2026-07-24 07:30:43.920 | HD Request # 5 | Sending historical data logon request message.
2026-07-24 07:30:44.189 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-07-24 06:53:47. Record interval: 1. Symbol: EURUSD
2026-07-24 07:30:44.646 | HD Request # 5 | Decompressing data.
2026-07-24 07:30:44.933 | HD Request # 5 | Receiving Intraday data for EURUSD starting at 2026-07-24 06:53:47.337000
2026-07-24 07:30:44.938 | Socket (6) | CloseSocket call.
2026-07-24 07:30:44.938 | Socket (6) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:44.940 | Historical data download thread signaled to stop.
2026-07-24 07:30:44.942 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-07-24 06:53:47.337000.
2026-07-24 07:30:44.943 | HD Request # 5 | Received 1463 Intraday data records from 2026-07-24 06:53:47.337000 to 2026-07-24 07:30:45.080000 (37.0 minutes. Delay: -0.1 seconds) and wrote 1463 records for EURUSD
2026-07-24 07:30:44.947 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:30:45.080000
2026-07-24 07:30:44.948 | HD Request # 5 | Completion time: 1s.
2026-07-24 07:30:44.948 | HD Request # 5 | Intraday data download complete for EURUSD. Unique request ID: 5
2026-07-24 07:30:44.948 | Removing historical data download ID 5.
2026-07-24 07:30:44.948 | Real-time Intraday chart data file updates started for EURUSD
2026-07-24 07:30:44.949 | Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 6384
2026-07-24 07:30:44.949 | Intraday chart data file opened for EURUSD
2026-07-24 07:30:44.949 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:44.950 | Triggering next historical data download in queue.
2026-07-24 07:30:44.950 | HD Request # 6 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data
2026-07-24 07:30:44.959 | HD Request # 6 | Download start date-time: 2026-07-23 23:59:30.000000. File last date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:30:44.960 | HD Request # 6 | Using server: ds31.sierracharts.com port 10150
2026-07-24 07:30:45.177 | Socket (6) | Socket gracefully closed by remote side.
2026-07-24 07:30:45.177 | Socket (6) | Closed.
2026-07-24 07:30:45.471 | Socket (3) | Creating socket.
2026-07-24 07:30:45.471 | Socket (3) | New receive buffer size: 0
2026-07-24 07:30:45.471 | Socket (3) | Connecting to IP: 64.152.155.116.
2026-07-24 07:30:45.941 | HD Request # 6 | Setting DTC encoding to Binary VLS
2026-07-24 07:30:45.941 | HD Request # 6 | Sending historical data logon request message.
2026-07-24 07:30:46.208 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-07-23 23:59:30. Record interval: 1. Symbol: AAPL-NQTV
2026-07-24 07:30:46.442 | HD Request # 6 | Decompressing data.
2026-07-24 07:30:46.745 | HD Request # 6 | Receiving Intraday data for AAPL-NQTV starting at 2026-07-23 23:59:30.503000
2026-07-24 07:30:46.747 | Socket (3) | CloseSocket call.
2026-07-24 07:30:46.748 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:30:46.903 | Historical data download thread signaled to stop.
2026-07-24 07:30:46.903 | HD Request # 6 | Timestamp of first Intraday data file record written: 2026-07-23 23:59:30.503000.
2026-07-24 07:30:46.904 | HD Request # 6 | Received 1 Intraday data record from 2026-07-23 23:59:30.503000 to 2026-07-23 23:59:30.503000 (0.0 seconds. Delay: 7.5 hours) and wrote 1 record for AAPL-NQTV
2026-07-24 07:30:46.905 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:30:46.905 | HD Request # 6 | Completion time: 2s.
2026-07-24 07:30:46.905 | HD Request # 6 | Intraday data download complete for AAPL-NQTV. Unique request ID: 6
2026-07-24 07:30:46.905 | Removing historical data download ID 6.
2026-07-24 07:30:46.905 | Real-time Intraday chart data file updates started for AAPL-NQTV
2026-07-24 07:30:46.906 | Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 6384
2026-07-24 07:30:46.906 | Intraday chart data file opened for AAPL-NQTV
2026-07-24 07:30:46.906 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2026-07-24 07:30:46.906 | No download requests in the queue to start downloads for.
2026-07-24 07:30:46.982 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:30:46.982 | Socket (3) | Closed.
2026-07-24 07:33:40.396 | ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 07:33:40.472 | Added historical Intraday data request for ESU6.CME to the queue.
2026-07-24 07:33:40.473 | Intraday data recording state for symbol ESU6.CME is set to download 'Pending'.
2026-07-24 07:33:40.475 | Triggering next historical data download in queue.
2026-07-24 07:33:40.480 | ESU6.CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol ESU6.CME starting at last date in file.
2026-07-24 07:33:40.480 | Starting DelayedDownloadMonitoringTimer
2026-07-24 07:33:40.480 | Starting HDTimeoutTimer
2026-07-24 07:33:40.480 | Added historical Daily data request for ESU6.CME to the queue.
2026-07-24 07:33:40.482 | Triggering next historical data download in queue.
2026-07-24 07:33:40.671 | ESU6.CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:40.809 | ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 07:33:41.017 | ESU6.CME [CBV] 2500 Volume #3 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:42.325 | ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 07:33:42.395 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffd65130000
2026-07-24 07:33:42.543 | ESU6.CME [CBV] Daily #5 | Reloading chart.
2026-07-24 07:33:43.036 | ESU6.CME [CBV] Daily #5 | Waiting for historical downloads to complete with the IDs: 8,
2026-07-24 07:33:43.207 | ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 07:33:43.355 | ESU6.CME [CBV] 540000 Volume #6 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:43.576 | ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 07:33:43.829 | ESU6.CME [CBV] 180000 Volume #7 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:44.028 | ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 07:33:44.114 | ESU6.CME [CBV] 100000 Volume #8 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:44.292 | ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 07:33:44.377 | ESU6.CME [CBV] 3000 Volume #1 | Waiting for historical downloads to complete with the IDs: 7, 8,
2026-07-24 07:33:44.526 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 07:33:44.533 | Added historical Intraday data request for MESU5.CME to the queue.
2026-07-24 07:33:44.546 | Added historical Intraday data request for MESZ5.CME to the queue.
2026-07-24 07:33:44.558 | Added historical Intraday data request for MESH6.CME to the queue.
2026-07-24 07:33:44.570 | Added historical Intraday data request for MESM6.CME to the queue.
2026-07-24 07:33:44.575 | Added historical Intraday data request for MESU6.CME to the queue.
2026-07-24 07:33:44.582 | MESU6.CME [CBV] 2500 Volume #9 | Performing continuous chart historical Daily data download for symbol MESU6.CME starting at last date in file.
2026-07-24 07:33:44.582 | Added historical Daily data request for MESU6.CME to the queue.
2026-07-24 07:33:44.803 | MESU6.CME [CBV] 2500 Volume #9 | Waiting for historical downloads to complete with the IDs: 9, 10, 11, 12, 13, 14,
2026-07-24 07:33:46.302 | HD Request # 7 | Downloading Intraday chart data for ESU6.CME to the file ESU6.CME.scid. Service: rithmic.trading
2026-07-24 07:33:46.306 | HD Request # 7 | Download start date-time: 2026-07-24 07:33:40.000000. File last date-time: 2026-07-24 07:33:40.000000
2026-07-24 07:33:46.310 | HD Request # 7 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:33:46.312 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:33:46.314 | Socket (3) | New receive buffer size: 0
2026-07-24 07:33:46.314 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:33:46.317 | HD Request # 8 | Downloading Historical Daily chart data for ESU6.CME. Starting date: 2026-07-21. Service: rithmic.trading
2026-07-24 07:33:46.541 | HD Request # 7 | Sending historical data logon request message.
2026-07-24 07:33:47.246 | HD Request # 7 | Requesting Intraday data. Start date-time: 2026-07-24 07:33:40. Record interval: 1. Symbol: ESU6.CME
2026-07-24 07:33:47.498 | HD Request # 7 | Receiving Intraday data for ESU6.CME starting at 2026-07-24 07:33:40.000000
2026-07-24 07:33:47.502 | Socket (3) | CloseSocket call.
2026-07-24 07:33:47.503 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:33:47.721 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:33:47.721 | Socket (3) | Closed.
2026-07-24 07:33:48.263 | Historical data download thread signaled to stop.
2026-07-24 07:33:48.263 | HD Request # 7 | Timestamp of first Intraday data file record written: 2026-07-24 07:33:40.000000.
2026-07-24 07:33:48.264 | HD Request # 7 | Received 7 Intraday data records from 2026-07-24 07:33:40.000000 to 2026-07-24 07:33:47.000000 (7.0 seconds. Delay: 1.3 seconds) and wrote 7 records for ESU6.CME
2026-07-24 07:33:48.267 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:33:47.000000
2026-07-24 07:33:48.269 | Added 1 Time and Sales records to Intraday data file for ESU6.CME after download.
2026-07-24 07:33:48.269 | HD Request # 7 | Completion time: 2s.
2026-07-24 07:33:48.269 | HD Request # 7 | Intraday data download complete for ESU6.CME. Unique request ID: 7
2026-07-24 07:33:48.269 | Removing historical data download ID 7.
2026-07-24 07:33:48.269 | Real-time Intraday chart data file updates started for ESU6.CME
2026-07-24 07:33:48.271 | Opened cached Intraday file: C:\SierraChart\Data\ESU6.CME.scid. Thread ID: 6384
2026-07-24 07:33:48.271 | Intraday chart data file opened for ESU6.CME
2026-07-24 07:33:48.271 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2026-07-24 07:33:48.271 | Triggering next historical data download in queue.
2026-07-24 07:33:48.288 | ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:33:48.842 | ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 07:33:48.852 | HD Request # 9 | Downloading Intraday chart data for MESU5.CME to the file MESU5.CME.scid. Service: rithmic.trading
2026-07-24 07:33:48.881 | HD Request # 9 | Download start date-time: 2025-06-23 11:56:58.000000. File last date-time: 2025-06-23 11:56:58.000000
2026-07-24 07:33:48.881 | HD Request # 9 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:33:48.881 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:33:48.882 | Socket (3) | New receive buffer size: 0
2026-07-24 07:33:48.882 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:33:49.105 | HD Request # 9 | Sending historical data logon request message.
2026-07-24 07:33:49.541 | HD Request # 8 | Requesting historical Daily data for ESU26 starting at 2026-07-20. SC External HD service.
2026-07-24 07:33:49.787 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-06-23 11:56:58. Record interval: 1. Symbol: MESU5.CME
2026-07-24 07:33:50.021 | HD Request # 9 | Receiving Intraday data for MESU5.CME starting at 2025-06-23 11:56:58.000000
2026-07-24 07:33:51.525 | HD Request # 8 | Receiving historical Daily data for ESU6.CME starting at 2026-07-21.
2026-07-24 07:33:51.527 | HD Request # 8 | Writing historical Daily data to the file ESU6.CME.dly.
2026-07-24 07:33:51.541 | HD Request # 8 | Bytes received: 290
2026-07-24 07:33:51.541 | HD Request # 8 | Received 5 Daily data records from 2026-07-21 00:00:00 to 2026-07-24 00:00:00 (4.0 days) and wrote 4 records for ESU6.CME
2026-07-24 07:33:51.541 | HD Request # 8 | Completion time: 5s.
2026-07-24 07:33:51.541 | HD Request # 8 | Daily data download complete for ESU6.CME. Unique request ID: 8
2026-07-24 07:33:51.541 | Removing historical data download ID 8.
2026-07-24 07:33:51.542 | Triggering next historical data download in queue.
2026-07-24 07:33:51.548 | HD Request # 10 | Downloading Historical Daily chart data for MESU6.CME. Starting date: 2026-07-21. Service: rithmic.trading
2026-07-24 07:33:51.604 | ESU6.CME [CBV] 3000 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:51.606 | ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 07:33:51.711 | ESU6.CME [CBV] 180000 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:51.714 | ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 07:33:52.127 | ESU6.CME [CBV] 540000 Volume #6 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:52.128 | ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 07:33:52.281 | ESU6.CME [CBV] 100000 Volume #8 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:52.283 | ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 07:33:52.370 | ESU6.CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:52.372 | ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 07:33:53.443 | HD Request # 10 | Requesting historical Daily data for ETU26 starting at 2026-07-20. SC External HD service.
2026-07-24 07:33:55.337 | ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:33:55.369 | ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 07:33:55.420 | ESU6.CME [CBV] 2500 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:55.456 | ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 07:33:55.681 | ESU6.CME [CBV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:33:55.684 | ESU6.CME [CBV] Daily #5 | Reloading chart.
2026-07-24 07:33:56.246 | HD Request # 10 | Receiving historical Daily data for MESU6.CME starting at 2026-07-21.
2026-07-24 07:33:56.248 | HD Request # 10 | Writing historical Daily data to the file MESU6.CME.dly.
2026-07-24 07:33:56.254 | HD Request # 10 | Bytes received: 291
2026-07-24 07:33:56.254 | HD Request # 10 | Received 5 Daily data records from 2026-07-21 00:00:00 to 2026-07-24 00:00:00 (4.0 days) and wrote 4 records for MESU6.CME
2026-07-24 07:33:56.254 | HD Request # 10 | Completion time: 5s.
2026-07-24 07:33:56.254 | HD Request # 10 | Daily data download complete for MESU6.CME. Unique request ID: 14
2026-07-24 07:33:56.254 | Removing historical data download ID 14.
2026-07-24 07:33:56.254 | No download requests in the queue to start downloads for.
2026-07-24 07:33:56.269 | ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 07:33:56.277 | ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 07:33:56.418 | ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 07:33:57.071 | ESU6.CME [CBV] Daily #5 | Chart data loading complete.
2026-07-24 07:33:57.084 | ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 07:33:57.999 | ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 07:33:58.494 | ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:33:58.525 | ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 07:33:58.575 | ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 07:33:59.363 | ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 07:33:59.949 | ESU6.CME [CBV] Daily #5 | Reloading chart.
2026-07-24 07:34:02.021 | ESU6.CME [CBV] Daily #5 | Chart data loading complete.
2026-07-24 07:34:03.317 | ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 07:34:05.672 | ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 07:34:08.587 | ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 07:34:13.512 | ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 07:34:25.121 | ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:34:26.106 | ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 07:34:31.677 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-06-23 11:56:58.000000.
2026-07-24 07:35:24.599 | Socket (3) | CloseSocket call.
2026-07-24 07:35:24.601 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:35:24.804 | HD Request # 9 | Error downloading historical Intraday data for MESU5.CME. output inhibited
2026-07-24 07:35:24.804 | Historical data download thread signaled to stop.
2026-07-24 07:35:24.805 | HD Request # 9 | Received 99996 Intraday data records from 2025-06-23 11:56:58.000000 to 2025-06-25 11:16:41.000000 (47.3 hours. Delay: 393.8 days) and wrote 99996 records for MESU5.CME
2026-07-24 07:35:24.812 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-06-25 11:16:41.000000
2026-07-24 07:35:24.813 | HD Request # 9 | Completion time: 1m 36s.
2026-07-24 07:35:24.813 | HD Request # 9 | Intraday data download complete for MESU5.CME. Unique request ID: 9
2026-07-24 07:35:24.813 | Removing historical data download ID 9.
2026-07-24 07:35:24.814 | Real-time Intraday chart data file updates started for MESU5.CME
2026-07-24 07:35:24.818 | Opened cached Intraday file: C:\SierraChart\Data\MESU5.CME.scid. Thread ID: 6384
2026-07-24 07:35:24.818 | Intraday chart data file opened for MESU5.CME
2026-07-24 07:35:24.818 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2026-07-24 07:35:24.818 | Triggering next historical data download in queue.
2026-07-24 07:35:24.821 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:35:24.821 | Socket (3) | Closed.
2026-07-24 07:35:24.830 | HD Request # 11 | Downloading Intraday chart data for MESZ5.CME to the file MESZ5.CME.scid. Service: rithmic.trading
2026-07-24 07:35:24.835 | HD Request # 11 | Download start date-time: 2025-09-19 08:21:40.000000. File last date-time: 2025-09-19 08:21:40.000000
2026-07-24 07:35:24.837 | HD Request # 11 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:35:24.845 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:35:24.845 | Socket (3) | New receive buffer size: 0
2026-07-24 07:35:24.845 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:35:25.097 | HD Request # 11 | Sending historical data logon request message.
2026-07-24 07:35:25.773 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-09-19 08:21:40. Record interval: 1. Symbol: MESZ5.CME
2026-07-24 07:35:26.121 | HD Request # 11 | Receiving Intraday data for MESZ5.CME starting at 2025-09-19 08:21:40.000000
2026-07-24 07:35:51.157 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-09-19 08:21:40.000000.
2026-07-24 07:36:45.663 | Socket (3) | CloseSocket call.
2026-07-24 07:36:45.663 | HD Request # 11 | Error downloading historical Intraday data for MESZ5.CME. output inhibited
2026-07-24 07:36:45.663 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:36:45.665 | Historical data download thread signaled to stop.
2026-07-24 07:36:45.667 | HD Request # 11 | Received 99996 Intraday data records from 2025-09-19 08:21:40.000000 to 2025-09-23 17:05:46.000000 (4.4 days. Delay: 303.6 days) and wrote 99996 records for MESZ5.CME
2026-07-24 07:36:45.672 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-09-23 17:05:46.000000
2026-07-24 07:36:45.673 | HD Request # 11 | Completion time: 1m 21s.
2026-07-24 07:36:45.673 | HD Request # 11 | Intraday data download complete for MESZ5.CME. Unique request ID: 10
2026-07-24 07:36:45.673 | Removing historical data download ID 10.
2026-07-24 07:36:45.673 | Real-time Intraday chart data file updates started for MESZ5.CME
2026-07-24 07:36:45.673 | Opened cached Intraday file: C:\SierraChart\Data\MESZ5.CME.scid. Thread ID: 6384
2026-07-24 07:36:45.673 | Intraday chart data file opened for MESZ5.CME
2026-07-24 07:36:45.673 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2026-07-24 07:36:45.673 | Triggering next historical data download in queue.
2026-07-24 07:36:45.674 | HD Request # 12 | Downloading Intraday chart data for MESH6.CME to the file MESH6.CME.scid. Service: rithmic.trading
2026-07-24 07:36:45.677 | HD Request # 12 | Download start date-time: 2025-12-17 16:30:36.000000. File last date-time: 2025-12-17 16:30:36.000000
2026-07-24 07:36:45.677 | HD Request # 12 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:36:45.677 | Socket (6) | Creating socket. Using TLS 1.2.
2026-07-24 07:36:45.680 | Socket (6) | New receive buffer size: 0
2026-07-24 07:36:45.680 | Socket (6) | Connecting to IP: 184.105.22.231.
2026-07-24 07:36:45.883 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:36:45.884 | Socket (3) | Closed.
2026-07-24 07:36:45.898 | HD Request # 12 | Sending historical data logon request message.
2026-07-24 07:36:46.555 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-12-17 16:30:36. Record interval: 1. Symbol: MESH6.CME
2026-07-24 07:36:46.779 | HD Request # 12 | Receiving Intraday data for MESH6.CME starting at 2025-12-17 16:30:36.000000
2026-07-24 07:37:08.147 | HD Request # 12 | Timestamp of first Intraday data file record written: 2025-12-17 16:30:36.000000.
2026-07-24 07:37:21.640 | ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:37:57.833 | Socket (6) | CloseSocket call.
2026-07-24 07:37:57.836 | Socket (6) | Shutdown started. Waiting for graceful close.
2026-07-24 07:37:57.854 | HD Request # 12 | Error downloading historical Intraday data for MESH6.CME. output inhibited
2026-07-24 07:37:57.855 | Historical data download thread signaled to stop.
2026-07-24 07:37:57.858 | HD Request # 12 | Received 99996 Intraday data records from 2025-12-17 16:30:36.000000 to 2025-12-19 15:14:05.000000 (46.7 hours. Delay: 216.7 days) and wrote 99996 records for MESH6.CME
2026-07-24 07:37:57.866 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-12-19 15:14:05.000000
2026-07-24 07:37:57.866 | HD Request # 12 | Completion time: 1m 12s.
2026-07-24 07:37:57.867 | HD Request # 12 | Intraday data download complete for MESH6.CME. Unique request ID: 11
2026-07-24 07:37:57.867 | Removing historical data download ID 11.
2026-07-24 07:37:57.868 | Real-time Intraday chart data file updates started for MESH6.CME
2026-07-24 07:37:57.870 | Opened cached Intraday file: C:\SierraChart\Data\MESH6.CME.scid. Thread ID: 6384
2026-07-24 07:37:57.871 | Intraday chart data file opened for MESH6.CME
2026-07-24 07:37:57.871 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2026-07-24 07:37:57.871 | Triggering next historical data download in queue.
2026-07-24 07:37:57.884 | HD Request # 13 | Downloading Intraday chart data for MESM6.CME to the file MESM6.CME.scid. Service: rithmic.trading
2026-07-24 07:37:57.891 | HD Request # 13 | Download start date-time: 2026-03-16 22:22:51.000000. File last date-time: 2026-03-16 22:22:51.000000
2026-07-24 07:37:57.893 | HD Request # 13 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:37:57.897 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:37:57.913 | Socket (3) | New receive buffer size: 0
2026-07-24 07:37:57.913 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:37:58.059 | Socket (6) | Socket gracefully closed by remote side.
2026-07-24 07:37:58.059 | Socket (6) | Closed.
2026-07-24 07:37:58.146 | HD Request # 13 | Sending historical data logon request message.
2026-07-24 07:37:58.844 | HD Request # 13 | Requesting Intraday data. Start date-time: 2026-03-16 22:22:51. Record interval: 1. Symbol: MESM6.CME
2026-07-24 07:37:59.077 | HD Request # 13 | Receiving Intraday data for MESM6.CME starting at 2026-03-16 22:22:51.000000
2026-07-24 07:38:27.137 | HD Request # 13 | Timestamp of first Intraday data file record written: 2026-03-16 22:22:51.000000.
2026-07-24 07:38:52.505 | Socket (3) | CloseSocket call.
2026-07-24 07:38:52.510 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:38:52.726 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:38:52.727 | Socket (3) | Closed.
2026-07-24 07:38:53.563 | HD Request # 13 | Error downloading historical Intraday data for MESM6.CME. output inhibited
2026-07-24 07:38:53.564 | Historical data download thread signaled to stop.
2026-07-24 07:38:53.570 | HD Request # 13 | Received 99996 Intraday data records from 2026-03-16 22:22:51.000000 to 2026-03-18 17:02:40.000000 (42.7 hours. Delay: 127.6 days) and wrote 99996 records for MESM6.CME
2026-07-24 07:38:53.590 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2026-03-18 17:02:40.000000
2026-07-24 07:38:53.591 | HD Request # 13 | Completion time: 56s.
2026-07-24 07:38:53.591 | HD Request # 13 | Intraday data download complete for MESM6.CME. Unique request ID: 12
2026-07-24 07:38:53.591 | Removing historical data download ID 12.
2026-07-24 07:38:53.593 | Real-time Intraday chart data file updates started for MESM6.CME
2026-07-24 07:38:53.598 | Opened cached Intraday file: C:\SierraChart\Data\MESM6.CME.scid. Thread ID: 6384
2026-07-24 07:38:53.601 | Intraday chart data file opened for MESM6.CME
2026-07-24 07:38:53.601 | HD Request # 13 | Enabling Intraday chart updating for symbol.
2026-07-24 07:38:53.602 |
2026-07-24 07:38:53.603 | Triggering next historical data download in queue.
2026-07-24 07:38:53.613 | HD Request # 14 | Downloading Intraday chart data for MESU6.CME to the file MESU6.CME.scid. Service: rithmic.trading
2026-07-24 07:38:53.646 | HD Request # 14 | Download start date-time: 2026-07-23 15:04:38.000000. File last date-time: 2026-07-23 15:04:38.000000
2026-07-24 07:38:53.656 | HD Request # 14 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 07:38:53.678 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 07:38:53.706 | Socket (3) | New receive buffer size: 0
2026-07-24 07:38:53.706 | Socket (3) | Connecting to IP: 184.105.22.231.
2026-07-24 07:38:53.951 | HD Request # 14 | Sending historical data logon request message.
2026-07-24 07:38:54.817 | HD Request # 14 | Requesting Intraday data. Start date-time: 2026-07-23 15:04:38. Record interval: 1. Symbol: MESU6.CME
2026-07-24 07:38:55.049 | HD Request # 14 | Receiving Intraday data for MESU6.CME starting at 2026-07-23 15:04:38.000000
2026-07-24 07:39:05.174 | HD Request # 14 | Timestamp of first Intraday data file record written: 2026-07-23 15:04:38.000000.
2026-07-24 07:39:06.972 | Socket (3) | CloseSocket call.
2026-07-24 07:39:06.972 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:39:07.188 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:39:07.189 | Socket (3) | Closed.
2026-07-24 07:39:07.194 | Historical data download thread signaled to stop.
2026-07-24 07:39:07.196 | HD Request # 14 | Received 40602 Intraday data records from 2026-07-23 15:04:38.000000 to 2026-07-24 07:38:56.000000 (16.6 hours. Delay: 11.2 seconds) and wrote 40602 records for MESU6.CME
2026-07-24 07:39:07.199 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2026-07-24 07:38:56.000000
2026-07-24 07:39:07.199 | HD Request # 14 | Completion time: 14s.
2026-07-24 07:39:07.199 | HD Request # 14 | Intraday data download complete for MESU6.CME. Unique request ID: 13
2026-07-24 07:39:07.199 | Removing historical data download ID 13.
2026-07-24 07:39:07.199 | Real-time Intraday chart data file updates started for MESU6.CME
2026-07-24 07:39:07.201 | Opened cached Intraday file: C:\SierraChart\Data\MESU6.CME.scid. Thread ID: 6384
2026-07-24 07:39:07.202 | Intraday chart data file opened for MESU6.CME
2026-07-24 07:39:07.202 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2026-07-24 07:39:07.202 | No download requests in the queue to start downloads for.
2026-07-24 07:39:07.229 | MESU6.CME [CBV] 2500 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 07:39:07.268 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart. | Number times message added: 1
2026-07-24 07:39:08.951 | MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 07:39:09.025 | MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 07:39:09.318 | Rithmic Direct - DTC | Starting real-time market data updates for: MESU6.CME. ID: 11 Service code: rithmic.trading
2026-07-24 07:39:09.325 | Rithmic Direct - DTC | Requesting security definition data for: MESU6.CME. ID: 11
2026-07-24 07:41:14.429 | Delayed Data Feed | Real-time data for symbol AAPL-NQTV is currently unavailable.
2026-07-24 07:41:36.984 | Delayed Data Feed | Setting external service identifier for symbol AAPL-NQTV to 41
2026-07-24 07:41:36.985 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV
2026-07-24 07:41:36.987 | Delayed Data Feed | Real-time data for symbol AAPL-NQTV has been restored.
2026-07-24 07:41:37.009 | Added historical Intraday data request for AAPL-NQTV to the queue.
2026-07-24 07:41:37.010 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'.
2026-07-24 07:41:37.012 | Triggering next historical data download in queue.
2026-07-24 07:41:37.021 | HD Request # 15 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data
2026-07-24 07:41:37.037 | HD Request # 15 | Download start date-time: 2026-07-23 23:59:30.000000. File last date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:41:37.043 | HD Request # 15 | Using server: ds33.sierracharts.com port 10149
2026-07-24 07:41:37.128 | Socket (3) | Creating socket.
2026-07-24 07:41:37.130 | Socket (3) | New receive buffer size: 0
2026-07-24 07:41:37.130 | Socket (3) | Connecting to IP: 69.39.70.245.
2026-07-24 07:41:37.629 | HD Request # 15 | Setting DTC encoding to Binary VLS
2026-07-24 07:41:37.629 | HD Request # 15 | Sending historical data logon request message.
2026-07-24 07:41:38.245 | HD Request # 15 | Requesting Intraday data. Start date-time: 2026-07-23 23:59:30. Record interval: 1. Symbol: AAPL-NQTV
2026-07-24 07:41:38.487 | HD Request # 15 | Decompressing data.
2026-07-24 07:41:38.730 | HD Request # 15 | Receiving Intraday data for AAPL-NQTV starting at 2026-07-23 23:59:30.503000
2026-07-24 07:41:38.732 | Socket (3) | CloseSocket call.
2026-07-24 07:41:38.733 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:41:38.948 | Historical data download thread signaled to stop.
2026-07-24 07:41:38.948 | HD Request # 15 | Timestamp of first Intraday data file record written: 2026-07-23 23:59:30.503000.
2026-07-24 07:41:38.949 | HD Request # 15 | Received 1 Intraday data record from 2026-07-23 23:59:30.503000 to 2026-07-23 23:59:30.503000 (0.0 seconds. Delay: 7.7 hours) and wrote 1 record for AAPL-NQTV
2026-07-24 07:41:38.953 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:41:38.954 | HD Request # 15 | Completion time: 1s.
2026-07-24 07:41:38.954 | HD Request # 15 | Intraday data download complete for AAPL-NQTV. Unique request ID: 15
2026-07-24 07:41:38.954 | Removing historical data download ID 15.
2026-07-24 07:41:38.954 | Real-time Intraday chart data file updates started for AAPL-NQTV
2026-07-24 07:41:38.958 | Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 6384
2026-07-24 07:41:38.958 | Intraday chart data file opened for AAPL-NQTV
2026-07-24 07:41:38.959 | HD Request # 15 | Enabling Intraday chart updating for symbol.
2026-07-24 07:41:38.959 | No download requests in the queue to start downloads for.
2026-07-24 07:41:38.970 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:41:38.971 | Socket (3) | Closed.
2026-07-24 07:56:35.859 | Delayed Data Feed | Real-time data for symbol AAPL-NQTV has been restored.
2026-07-24 07:56:35.867 | Added historical Intraday data request for AAPL-NQTV to the queue.
2026-07-24 07:56:35.868 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'.
2026-07-24 07:56:35.868 | Triggering next historical data download in queue.
2026-07-24 07:56:35.869 | HD Request # 16 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data
2026-07-24 07:56:35.880 | HD Request # 16 | Download start date-time: 2026-07-23 23:59:30.000000. File last date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:56:35.884 | HD Request # 16 | Using server: ds30.sierracharts.com port 10150
2026-07-24 07:56:35.890 | Socket (3) | Creating socket.
2026-07-24 07:56:35.890 | Socket (3) | New receive buffer size: 0
2026-07-24 07:56:35.890 | Socket (3) | Connecting to IP: 67.214.125.11.
2026-07-24 07:56:36.407 | HD Request # 16 | Setting DTC encoding to Binary VLS
2026-07-24 07:56:36.407 | HD Request # 16 | Sending historical data logon request message.
2026-07-24 07:56:36.699 | HD Request # 16 | Requesting Intraday data. Start date-time: 2026-07-23 23:59:30. Record interval: 1. Symbol: AAPL-NQTV
2026-07-24 07:56:36.946 | HD Request # 16 | Decompressing data.
2026-07-24 07:56:37.208 | HD Request # 16 | Receiving Intraday data for AAPL-NQTV starting at 2026-07-23 23:59:30.503000
2026-07-24 07:56:37.209 | Socket (3) | CloseSocket call.
2026-07-24 07:56:37.210 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 07:56:37.212 | Historical data download thread signaled to stop.
2026-07-24 07:56:37.212 | HD Request # 16 | Timestamp of first Intraday data file record written: 2026-07-23 23:59:30.503000.
2026-07-24 07:56:37.212 | HD Request # 16 | Received 1 Intraday data record from 2026-07-23 23:59:30.503000 to 2026-07-23 23:59:30.503000 (0.0 seconds. Delay: 8.0 hours) and wrote 1 record for AAPL-NQTV
2026-07-24 07:56:37.213 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2026-07-23 23:59:30.503000
2026-07-24 07:56:37.214 | HD Request # 16 | Completion time: 2s.
2026-07-24 07:56:37.214 | HD Request # 16 | Intraday data download complete for AAPL-NQTV. Unique request ID: 16
2026-07-24 07:56:37.214 | Removing historical data download ID 16.
2026-07-24 07:56:37.214 | Real-time Intraday chart data file updates started for AAPL-NQTV
2026-07-24 07:56:37.216 | Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 6384
2026-07-24 07:56:37.216 | Intraday chart data file opened for AAPL-NQTV
2026-07-24 07:56:37.216 | HD Request # 16 | Enabling Intraday chart updating for symbol.
2026-07-24 07:56:37.216 | No download requests in the queue to start downloads for.
2026-07-24 07:56:37.457 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 07:56:37.458 | Socket (3) | Closed.
2026-07-24 08:28:23.336 | ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:28:42.989 | Paused 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:28:43.157 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:28:43.330 | Paused 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:28:43.338 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:28:43.425 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:28:43.659 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:28:43.731 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:28:43.823 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:28:45.025 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:28:45.069 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:28:45.190 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:28:45.253 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:28:45.974 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:28:46.751 | Paused 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:28:47.198 | Paused 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:28:48.869 | Paused 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:28:49.344 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:28:52.719 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:28:54.781 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:32:04.419 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:54.000
2026-07-24 08:32:04.419 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:54.000
2026-07-24 08:32:04.419 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:54.000
2026-07-24 08:32:04.420 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:54.000
2026-07-24 08:32:04.420 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:54.000
2026-07-24 08:32:04.420 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:54.000
2026-07-24 08:32:04.420 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:54.000
2026-07-24 08:32:04.420 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:54.000
2026-07-24 08:32:05.420 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:55.000
2026-07-24 08:32:05.420 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:55.000
2026-07-24 08:32:05.420 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:55.000
2026-07-24 08:32:05.420 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:55.000
2026-07-24 08:32:05.420 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:55.000
2026-07-24 08:32:05.421 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:55.000
2026-07-24 08:32:05.421 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:55.000
2026-07-24 08:32:05.421 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:55.000
2026-07-24 08:32:06.388 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:56.000
2026-07-24 08:32:06.388 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:56.000
2026-07-24 08:32:06.388 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:56.000
2026-07-24 08:32:06.388 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:56.000
2026-07-24 08:32:06.389 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:56.000
2026-07-24 08:32:06.389 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:56.000
2026-07-24 08:32:06.389 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:56.000
2026-07-24 08:32:06.390 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:56.000
2026-07-24 08:32:07.142 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:56.000
2026-07-24 08:32:07.142 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:56.000
2026-07-24 08:32:07.143 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:56.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:57.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:57.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:57.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:40:57.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:40:57.000
2026-07-24 08:32:07.884 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:40:57.000
2026-07-24 08:32:07.885 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:57.000
2026-07-24 08:32:07.885 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:57.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:58.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:58.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:58.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:58.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:58.000
2026-07-24 08:32:08.692 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:58.000
2026-07-24 08:32:08.694 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:58.000
2026-07-24 08:32:08.694 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:58.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:00.000
2026-07-24 08:32:09.779 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:00.000
2026-07-24 08:32:09.780 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:00.000
2026-07-24 08:32:10.835 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:01.000
2026-07-24 08:32:10.836 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:01.000
2026-07-24 08:32:46.669 | Paused 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:32:46.808 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:32:47.007 | Paused 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:32:47.012 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:32:47.120 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:32:47.326 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:32:47.392 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:32:47.539 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:32:48.731 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:32:48.789 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:32:48.791 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:32:48.852 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:32:49.914 | Paused 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:32:50.213 | Paused 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:32:50.586 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:32:53.251 | Paused 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:32:53.742 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:32:57.263 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:32:59.527 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:32:59.886 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:20.000
2026-07-24 08:33:50.679 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:20.000
2026-07-24 08:33:52.635 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:23.000
2026-07-24 08:33:52.635 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:23.000
2026-07-24 08:33:52.636 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:23.000
2026-07-24 08:34:35.315 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:47.000
2026-07-24 08:34:35.315 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:47.000
2026-07-24 08:34:35.315 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:47.000
2026-07-24 08:34:35.316 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:47.000
2026-07-24 08:34:35.316 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:47.000
2026-07-24 08:34:35.316 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:47.000
2026-07-24 08:34:35.316 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:47.000
2026-07-24 08:34:35.316 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:47.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:12.000
2026-07-24 08:35:18.427 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:12.000
2026-07-24 08:35:18.428 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:12.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:13.000
2026-07-24 08:35:19.592 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:13.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:19.000
2026-07-24 08:35:22.964 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:19.000
2026-07-24 08:35:55.995 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:24.000
2026-07-24 08:35:55.995 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:24.000
2026-07-24 08:35:55.996 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:24.000
2026-07-24 08:36:20.254 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:11.000
2026-07-24 08:36:20.255 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:11.000
2026-07-24 08:36:20.907 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:11.000
2026-07-24 08:36:20.907 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:11.000
2026-07-24 08:36:20.907 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:11.000
2026-07-24 08:36:20.907 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:11.000
2026-07-24 08:36:20.908 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:11.000
2026-07-24 08:36:20.908 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:11.000
2026-07-24 08:36:20.908 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:11.000
2026-07-24 08:36:20.908 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:11.000
2026-07-24 08:36:21.675 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:12.000
2026-07-24 08:36:21.675 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:12.000
2026-07-24 08:36:21.676 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:12.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:30.000
2026-07-24 08:36:31.206 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:30.000
2026-07-24 08:36:36.983 | Replay 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:36:37.146 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:36:37.299 | Replay 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:36:37.308 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:36:37.394 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:36:37.605 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:36:37.706 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:36:37.832 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:36:38.841 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:36:38.870 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:36:39.039 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:36:39.097 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:36:39.982 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:36:40.063 | Replay 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:36:40.320 | Replay 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:36:41.892 | Replay 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:36:41.998 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:36:43.518 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:36:44.507 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:36:44.730 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:31.000
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:31.000
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:31.000
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:31.000
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:31.000
2026-07-24 08:37:02.931 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:31.000
2026-07-24 08:37:02.933 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:31.000
2026-07-24 08:37:02.933 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:31.000
2026-07-24 08:37:20.315 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:05.000
2026-07-24 08:37:20.315 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:05.000
2026-07-24 08:37:20.315 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:05.000
2026-07-24 08:37:20.315 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:05.000
2026-07-24 08:37:20.315 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:05.000
2026-07-24 08:37:20.316 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:05.000
2026-07-24 08:37:20.316 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:05.000
2026-07-24 08:37:20.316 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:05.000
2026-07-24 08:37:26.747 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:17.000
2026-07-24 08:37:26.747 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:17.000
2026-07-24 08:37:26.747 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:17.000
2026-07-24 08:37:26.748 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:17.000
2026-07-24 08:37:26.748 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:17.000
2026-07-24 08:37:26.748 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:17.000
2026-07-24 08:37:26.748 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:17.000
2026-07-24 08:37:26.748 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:17.000
2026-07-24 08:37:27.314 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:17.000
2026-07-24 08:37:27.314 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:17.000
2026-07-24 08:37:27.314 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:17.000
2026-07-24 08:37:27.314 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:17.000
2026-07-24 08:37:27.314 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:17.000
2026-07-24 08:37:27.315 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:17.000
2026-07-24 08:37:27.315 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:17.000
2026-07-24 08:37:27.315 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:17.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:30.000
2026-07-24 08:37:34.387 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:30.000
2026-07-24 08:37:36.579 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:34.000
2026-07-24 08:37:36.579 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:34.000
2026-07-24 08:37:36.579 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:34.000
2026-07-24 08:37:36.579 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:34.000
2026-07-24 08:37:36.580 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:34.000
2026-07-24 08:37:36.580 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:34.000
2026-07-24 08:37:36.580 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:34.000
2026-07-24 08:37:36.580 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:34.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.411 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.412 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:35.000
2026-07-24 08:37:37.667 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:37:37.668 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:35.000
2026-07-24 08:42:51.923 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:05.369 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:10.812 | ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:43:11.153 | ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:43:11.425 | ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:43:11.437 | ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:43:11.570 | ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:43:11.908 | ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:43:12.022 | ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:43:12.145 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:43:13.803 | ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:13.874 | ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:43:13.946 | MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:14.092 | MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:43:16.000 | ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:16.534 | ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:43:17.042 | ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:43:20.023 | ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:43:20.068 | ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:43:22.609 | ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:43:24.471 | ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:43:24.837 | ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:44:59.570 | Paused 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:44:59.802 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:45:00.037 | Paused 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:45:00.050 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:45:00.195 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:45:00.517 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:45:00.640 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:45:00.812 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:45:02.112 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:02.155 | Paused 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:45:02.653 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:02.792 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:45:04.567 | Paused 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:45:04.655 | Paused 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:05.123 | Paused 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:45:07.748 | Paused 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:45:07.879 | Paused 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:45:10.259 | Paused 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:45:11.611 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:11.877 | Paused 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:45:21.890 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:06.000
2026-07-24 08:45:21.890 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:06.000
2026-07-24 08:45:21.890 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:06.000
2026-07-24 08:45:21.891 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:31:06.000
2026-07-24 08:45:21.891 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:31:06.000
2026-07-24 08:45:21.891 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:31:06.000
2026-07-24 08:45:21.891 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:06.000
2026-07-24 08:45:21.891 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:06.000
2026-07-24 08:45:22.642 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:06.000
2026-07-24 08:45:22.642 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:06.000
2026-07-24 08:45:22.643 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:06.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:33:09.000
2026-07-24 08:45:24.514 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:09.000
2026-07-24 08:45:24.515 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:09.000
2026-07-24 08:45:33.411 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:26.000
2026-07-24 08:45:33.411 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:26.000
2026-07-24 08:45:33.411 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:26.000
2026-07-24 08:45:33.411 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:34:26.000
2026-07-24 08:45:33.412 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:34:26.000
2026-07-24 08:45:33.412 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:34:26.000
2026-07-24 08:45:33.412 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:26.000
2026-07-24 08:45:33.412 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:26.000
2026-07-24 08:45:34.871 | Replay 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:45:35.007 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:45:35.217 | Replay 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:45:35.222 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:45:35.333 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:45:35.612 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:45:35.683 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:45:35.766 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:45:36.649 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:36.675 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:45:36.702 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:36.755 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:45:37.775 | Replay 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:37.979 | Replay 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:45:38.253 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:45:40.254 | Replay 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:45:40.394 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:45:43.164 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:45:44.557 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:45:44.840 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:46:07.458 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:32.000
2026-07-24 08:46:07.458 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:32.000
2026-07-24 08:46:07.458 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:32.000
2026-07-24 08:46:07.458 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:35:32.000
2026-07-24 08:46:07.458 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:35:32.000
2026-07-24 08:46:07.459 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:35:32.000
2026-07-24 08:46:07.459 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:32.000
2026-07-24 08:46:07.459 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:32.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:32.000
2026-07-24 08:46:08.425 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:33.000
2026-07-24 08:46:08.425 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:33.000
2026-07-24 08:46:08.425 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:33.000
2026-07-24 08:46:08.425 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:33.000
2026-07-24 08:46:08.425 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:33.000
2026-07-24 08:46:08.426 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:36:33.000
2026-07-24 08:46:08.426 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:33.000
2026-07-24 08:46:08.426 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:33.000
2026-07-24 08:46:09.754 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:35.000
2026-07-24 08:46:09.755 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:36:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:37:35.000
2026-07-24 08:46:10.554 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:36.000
2026-07-24 08:46:10.554 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:36.000
2026-07-24 08:46:10.554 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:36.000
2026-07-24 08:46:10.555 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:36.000
2026-07-24 08:46:10.555 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:36.000
2026-07-24 08:46:10.556 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:38:36.000
2026-07-24 08:46:10.556 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:36.000
2026-07-24 08:46:10.557 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:36.000
2026-07-24 08:46:16.698 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:47.000
2026-07-24 08:46:16.698 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:47.000
2026-07-24 08:46:16.698 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:47.000
2026-07-24 08:46:16.699 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:47.000
2026-07-24 08:46:16.699 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:47.000
2026-07-24 08:46:16.699 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:39:47.000
2026-07-24 08:46:16.699 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:47.000
2026-07-24 08:46:16.699 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:47.000
2026-07-24 08:46:30.377 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:14.000
2026-07-24 08:46:30.377 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:14.000
2026-07-24 08:46:30.377 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:14.000
2026-07-24 08:46:30.378 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:14.000
2026-07-24 08:46:30.378 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:14.000
2026-07-24 08:46:30.378 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:41:14.000
2026-07-24 08:46:30.378 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:14.000
2026-07-24 08:46:30.378 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:14.000
2026-07-24 08:46:31.610 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:16.000
2026-07-24 08:46:31.610 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:16.000
2026-07-24 08:46:31.610 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:16.000
2026-07-24 08:46:31.610 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:16.000
2026-07-24 08:46:31.611 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:16.000
2026-07-24 08:46:31.612 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:42:16.000
2026-07-24 08:46:31.612 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:16.000
2026-07-24 08:46:31.612 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:16.000
2026-07-24 08:46:32.402 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:17.000
2026-07-24 08:46:32.402 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:17.000
2026-07-24 08:46:32.402 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:17.000
2026-07-24 08:46:32.403 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:17.000
2026-07-24 08:46:32.403 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:17.000
2026-07-24 08:46:32.403 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:43:17.000
2026-07-24 08:46:32.403 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:17.000
2026-07-24 08:46:32.403 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:17.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:41.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:41.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:41.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:41.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:41.000
2026-07-24 08:46:44.618 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:44:41.000
2026-07-24 08:46:44.619 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:41.000
2026-07-24 08:46:44.619 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:41.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:45:43.000
2026-07-24 08:46:46.139 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:44:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:45:43.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:47:16.000
2026-07-24 08:47:02.828 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:16.000
2026-07-24 08:47:02.829 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:16.000
2026-07-24 08:47:03.955 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:17.000
2026-07-24 08:47:03.955 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:17.000
2026-07-24 08:47:03.955 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:17.000
2026-07-24 08:47:03.955 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:17.000
2026-07-24 08:47:03.955 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:17.000
2026-07-24 08:47:03.956 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:48:17.000
2026-07-24 08:47:03.956 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:17.000
2026-07-24 08:47:03.956 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:17.000
2026-07-24 08:47:04.825 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:17.000
2026-07-24 08:47:04.825 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:17.000
2026-07-24 08:47:04.825 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:17.000
2026-07-24 08:47:04.825 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:17.000
2026-07-24 08:47:04.826 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:17.000
2026-07-24 08:47:04.826 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:49:17.000
2026-07-24 08:47:04.826 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:17.000
2026-07-24 08:47:04.826 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:17.000
2026-07-24 08:47:05.465 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:17.000
2026-07-24 08:47:05.465 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:17.000
2026-07-24 08:47:05.466 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:17.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:17.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:18.000
2026-07-24 08:47:06.186 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:18.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:52:51.000
2026-07-24 08:47:23.478 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:51:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:52:51.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:05.000
2026-07-24 08:47:31.018 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:05.000
2026-07-24 08:47:34.871 | Replay 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:47:35.116 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:47:35.388 | Replay 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:47:35.392 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:47:35.529 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:47:35.789 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:47:35.868 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:47:35.941 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:47:36.930 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:37.028 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:47:37.063 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:37.152 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:47:38.124 | Replay 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:38.397 | Replay 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:47:38.672 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:47:40.357 | Replay 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:47:40.367 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:47:42.401 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:47:43.903 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:44.179 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:47:57.160 | Replay 2.00X: ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:47:57.293 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:47:57.483 | Replay 2.00X: ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:47:57.488 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:47:57.576 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:47:57.788 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:47:57.854 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:47:57.928 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:47:58.858 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:58.918 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:47:58.920 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:47:58.947 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:47:59.884 | Replay 2.00X: ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:48:00.196 | Replay 2.00X: ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:48:00.545 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:48:02.981 | Replay 2.00X: ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:48:03.112 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:48:06.068 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:48:07.887 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:48:08.193 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:48:15.769 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 09:54:31.000
2026-07-24 08:48:15.769 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 09:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 09:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 13:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 13:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 13:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 09:54:31.000
2026-07-24 08:48:15.770 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:31.000. JumpTimeValue=2m. ReplayChartStartDateTime=2026-07-23 09:54:31.000
2026-07-24 08:48:46.474 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:31.000
2026-07-24 08:48:46.474 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:31.000
2026-07-24 08:48:46.474 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:31.000
2026-07-24 08:48:46.474 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:31.000
2026-07-24 08:48:46.474 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:31.000
2026-07-24 08:48:46.475 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:56:31.000
2026-07-24 08:48:46.475 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:31.000
2026-07-24 08:48:46.475 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:31.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:35.000
2026-07-24 08:48:48.550 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:35.000
2026-07-24 08:48:49.555 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:36.000
2026-07-24 08:48:49.556 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:36.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:36.000
2026-07-24 08:48:50.313 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:37.000
2026-07-24 08:48:50.313 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 13:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:37.000
2026-07-24 08:48:50.314 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:37.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.051 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.305 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 13:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:00:38.000
2026-07-24 08:48:51.306 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.307 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:38.000
2026-07-24 08:48:51.537 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:38.000
2026-07-24 08:48:51.538 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:38.000
2026-07-24 08:48:51.819 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:38.000
2026-07-24 08:48:52.226 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:03:38.000
2026-07-24 08:48:52.227 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:38.000
2026-07-24 08:48:52.228 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.635 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.636 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.970 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.970 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.970 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.970 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.971 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.971 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:04:38.000
2026-07-24 08:48:52.971 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:52.971 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:38.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:54.810 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:54.811 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.002 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.002 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.002 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.003 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:55.003 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:55.003 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:05:41.000
2026-07-24 08:48:55.004 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.004 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.195 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.196 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.196 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.393 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.394 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:41.000
2026-07-24 08:48:55.786 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:41.000
2026-07-24 08:48:55.787 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:08:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:08:41.000
2026-07-24 08:48:56.003 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:08:41.000
2026-07-24 08:48:56.004 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:41.000
2026-07-24 08:48:56.004 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:41.000
2026-07-24 08:48:56.417 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:41.000
2026-07-24 08:48:56.418 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:41.000
2026-07-24 08:48:56.986 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:41.000
2026-07-24 08:48:56.986 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:41.000
2026-07-24 08:48:56.986 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:41.000
2026-07-24 08:48:56.986 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:10:41.000
2026-07-24 08:48:56.986 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:10:41.000
2026-07-24 08:48:56.987 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:10:41.000
2026-07-24 08:48:56.987 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:41.000
2026-07-24 08:48:56.987 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:41.000
2026-07-24 08:48:57.850 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:11:41.000
2026-07-24 08:48:57.850 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:11:41.000
2026-07-24 08:48:57.850 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:11:41.000
2026-07-24 08:48:57.850 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:11:41.000
2026-07-24 08:48:57.850 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:11:41.000
2026-07-24 08:48:57.851 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:11:41.000
2026-07-24 08:48:57.851 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:11:41.000
2026-07-24 08:48:57.851 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:10:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:11:41.000
2026-07-24 08:48:58.337 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.338 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:58.698 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.137 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.506 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:13:41.000
2026-07-24 08:48:59.507 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:48:59.507 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:41.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:41.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:45.000
2026-07-24 08:49:01.675 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:45.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:45.000
2026-07-24 08:49:02.449 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:46.000
2026-07-24 08:49:02.449 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:46.000
2026-07-24 08:49:02.449 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:46.000
2026-07-24 08:49:02.449 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:15:46.000
2026-07-24 08:49:02.449 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:15:46.000
2026-07-24 08:49:02.450 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:15:46.000
2026-07-24 08:49:02.450 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:46.000
2026-07-24 08:49:02.450 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:46.000
2026-07-24 08:49:02.948 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:46.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:47.000
2026-07-24 08:49:03.598 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:47.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:47.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:48.000
2026-07-24 08:49:04.575 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:48.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:19:50.000
2026-07-24 08:49:05.907 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:50.000
2026-07-24 08:49:05.908 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:50.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:53.000
2026-07-24 08:49:07.674 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:53.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.481 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.482 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:08.738 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:54.000
2026-07-24 08:49:09.058 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:23:54.000
2026-07-24 08:49:09.363 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:54.000
2026-07-24 08:49:09.364 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:54.000
2026-07-24 08:49:10.025 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:54.000
2026-07-24 08:49:10.025 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:54.000
2026-07-24 08:49:10.026 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:54.000
2026-07-24 08:49:11.009 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:55.000
2026-07-24 08:49:11.009 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:55.000
2026-07-24 08:49:11.010 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:55.000
2026-07-24 08:49:11.010 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:25:55.000
2026-07-24 08:49:11.010 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:25:55.000
2026-07-24 08:49:11.012 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:25:55.000
2026-07-24 08:49:11.012 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:55.000
2026-07-24 08:49:11.012 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:55.000
2026-07-24 08:49:12.025 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:56.000
2026-07-24 08:49:12.025 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:56.000
2026-07-24 08:49:12.025 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:56.000
2026-07-24 08:49:12.025 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:26:56.000
2026-07-24 08:49:12.026 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:26:56.000
2026-07-24 08:49:12.026 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:26:56.000
2026-07-24 08:49:12.026 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:56.000
2026-07-24 08:49:12.026 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:56.000
2026-07-24 08:49:12.780 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:56.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:57.000
2026-07-24 08:49:13.706 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:57.000
2026-07-24 08:49:14.809 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:58.000
2026-07-24 08:49:14.809 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:58.000
2026-07-24 08:49:14.810 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:58.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:59.000
2026-07-24 08:49:15.783 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:59.000
2026-07-24 08:49:26.233 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 08:49:26.233 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 08:49:26.234 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 08:49:27.593 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:21.000
2026-07-24 08:49:27.593 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:21.000
2026-07-24 08:49:27.594 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:21.000
2026-07-24 08:49:29.002 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:23.000
2026-07-24 08:49:29.003 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:23.000
2026-07-24 08:49:30.522 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:25.000
2026-07-24 08:49:30.522 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:25.000
2026-07-24 08:49:30.522 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:25.000
2026-07-24 08:49:30.522 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:35:25.000
2026-07-24 08:49:30.523 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:35:25.000
2026-07-24 08:49:30.523 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:35:25.000
2026-07-24 08:49:30.523 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:25.000
2026-07-24 08:49:30.523 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:25.000
2026-07-24 08:49:31.473 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:26.000
2026-07-24 08:49:31.473 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:26.000
2026-07-24 08:49:31.474 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:26.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:26.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:27.000
2026-07-24 08:49:32.331 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:27.000
2026-07-24 08:50:07.681 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:37.000
2026-07-24 08:50:07.681 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:37.000
2026-07-24 08:50:07.681 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:37.000
2026-07-24 08:50:07.681 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:39:37.000
2026-07-24 08:50:07.682 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:39:37.000
2026-07-24 08:50:07.682 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:39:37.000
2026-07-24 08:50:07.684 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:37.000
2026-07-24 08:50:07.684 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:37.000
2026-07-24 08:50:13.009 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:46.000
2026-07-24 08:50:13.010 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:46.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:24.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:24.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:24.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:42:24.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:42:24.000
2026-07-24 08:50:32.257 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:42:24.000
2026-07-24 08:50:32.258 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:24.000
2026-07-24 08:50:32.258 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:24.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:24.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:49.000
2026-07-24 08:50:45.348 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:49.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:11.000
2026-07-24 08:50:56.652 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:11.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:28.000
2026-07-24 08:51:05.805 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:28.000
2026-07-24 08:51:08.984 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:33.000
2026-07-24 08:51:08.985 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:33.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:33.000
2026-07-24 08:51:10.337 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:35.000
2026-07-24 08:51:10.337 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:35.000
2026-07-24 08:51:10.337 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:35.000
2026-07-24 08:51:10.337 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:48:35.000
2026-07-24 08:51:10.337 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:48:35.000
2026-07-24 08:51:10.338 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:48:35.000
2026-07-24 08:51:10.338 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:35.000
2026-07-24 08:51:10.338 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:35.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:35.000
2026-07-24 08:51:35.897 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:25.000
2026-07-24 08:51:35.897 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:25.000
2026-07-24 08:51:35.897 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:25.000
2026-07-24 08:51:35.898 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:50:25.000
2026-07-24 08:51:35.898 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:50:25.000
2026-07-24 08:51:35.898 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:50:25.000
2026-07-24 08:51:35.898 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:25.000
2026-07-24 08:51:35.898 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:25.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:25.000
2026-07-24 08:51:40.849 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:34.000
2026-07-24 08:51:40.849 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:34.000
2026-07-24 08:51:40.850 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:34.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:34.000
2026-07-24 08:51:42.873 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:52:37.000
2026-07-24 08:51:42.873 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:52:37.000
2026-07-24 08:51:42.873 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:52:37.000
2026-07-24 08:51:42.873 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:52:37.000
2026-07-24 08:51:42.873 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:52:37.000
2026-07-24 08:51:42.874 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:52:37.000
2026-07-24 08:51:42.874 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:52:37.000
2026-07-24 08:51:42.874 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:51:37.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:52:37.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:53.000
2026-07-24 08:51:51.217 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:53.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:53.000
2026-07-24 08:51:53.817 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:56.000
2026-07-24 08:51:53.817 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:56.000
2026-07-24 08:51:53.820 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:56.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:56.000
2026-07-24 08:51:54.617 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:57.000
2026-07-24 08:51:54.617 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:57.000
2026-07-24 08:51:54.617 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:57.000
2026-07-24 08:51:54.617 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:55:57.000
2026-07-24 08:51:54.617 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:55:57.000
2026-07-24 08:51:54.618 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:55:57.000
2026-07-24 08:51:54.618 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:57.000
2026-07-24 08:51:54.618 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:57.000
2026-07-24 08:51:55.497 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:58.000
2026-07-24 08:51:55.498 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:58.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:57:59.000
2026-07-24 08:51:56.425 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:59.000
2026-07-24 08:51:56.426 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:59.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 14:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:00.000
2026-07-24 08:51:57.395 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:00.000
2026-07-24 08:51:58.438 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 14:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 14:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 14:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:02.000
2026-07-24 08:51:58.439 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:02.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:02.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:03.000
2026-07-24 08:51:59.609 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:03.000
2026-07-24 08:52:01.153 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:05.000
2026-07-24 08:52:01.153 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:05.000
2026-07-24 08:52:01.153 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:05.000
2026-07-24 08:52:01.153 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:02:05.000
2026-07-24 08:52:01.154 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:02:05.000
2026-07-24 08:52:01.154 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:02:05.000
2026-07-24 08:52:01.154 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:05.000
2026-07-24 08:52:01.154 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:05.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:05.000
2026-07-24 08:52:02.193 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:06.000
2026-07-24 08:52:02.193 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:06.000
2026-07-24 08:52:02.193 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:06.000
2026-07-24 08:52:02.193 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:03:06.000
2026-07-24 08:52:02.193 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:03:06.000
2026-07-24 08:52:02.194 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:03:06.000
2026-07-24 08:52:02.194 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:06.000
2026-07-24 08:52:02.194 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:06.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:06.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:08.000
2026-07-24 08:52:03.708 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:08.000
2026-07-24 08:52:05.017 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:10.000
2026-07-24 08:52:05.017 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:10.000
2026-07-24 08:52:05.017 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:10.000
2026-07-24 08:52:05.017 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:05:10.000
2026-07-24 08:52:05.017 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:05:10.000
2026-07-24 08:52:05.018 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:05:10.000
2026-07-24 08:52:05.018 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:10.000
2026-07-24 08:52:05.018 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:10.000
2026-07-24 08:52:06.041 | Replay 2.00X: ESU6.CME [CBV] #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:11.000
2026-07-24 08:52:06.041 | Replay 2.00X: ESU6.CME [CBV] 2500 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:11.000
2026-07-24 08:52:06.041 | Replay 2.00X: ESU6.CME Renko 4t #4 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:11.000
2026-07-24 08:52:06.042 | Replay 2.00X: ESU6.CME [CBV] 540000 Volume #6 | Replay jump | LastLoadedDateTime=2026-07-23 15:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:06:11.000
2026-07-24 08:52:06.042 | Replay 2.00X: ESU6.CME [CBV] 180000 Volume #7 | Replay jump | LastLoadedDateTime=2026-07-23 15:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:06:11.000
2026-07-24 08:52:06.042 | Replay 2.00X: ESU6.CME [CBV] 100000 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 15:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 15:06:11.000
2026-07-24 08:52:06.042 | Replay 2.00X: ESU6.CME [CBV] 3000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:11.000
2026-07-24 08:52:06.042 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #9 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:11.000
2026-07-24 08:52:31.831 | ESU6.CME [CBV] #2 | Reloading chart.
2026-07-24 08:52:31.982 | ESU6.CME [CBV] 2500 Volume #3 | Reloading chart.
2026-07-24 08:52:32.165 | ESU6.CME Renko 4t #4 | Reloading chart.
2026-07-24 08:52:32.177 | ESU6.CME [CBV] 540000 Volume #6 | Reloading chart.
2026-07-24 08:52:32.265 | ESU6.CME [CBV] 180000 Volume #7 | Reloading chart.
2026-07-24 08:52:32.478 | ESU6.CME [CBV] 100000 Volume #8 | Reloading chart.
2026-07-24 08:52:32.552 | ESU6.CME [CBV] 3000 Volume #1 | Reloading chart.
2026-07-24 08:52:32.642 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 08:52:33.660 | MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:52:33.736 | MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 08:52:33.825 | ESU6.CME [CBV] 3000 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:52:33.858 | ESU6.CME [CBV] 3000 Volume #1 | Chart data loading complete.
2026-07-24 08:52:35.039 | ESU6.CME [CBV] 100000 Volume #8 | Chart data loading complete.
2026-07-24 08:52:35.165 | ESU6.CME Renko 4t #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:52:35.379 | ESU6.CME Renko 4t #4 | Chart data loading complete.
2026-07-24 08:52:36.472 | ESU6.CME [CBV] #2 | Chart data loading complete.
2026-07-24 08:52:36.591 | ESU6.CME [CBV] 540000 Volume #6 | Chart data loading complete.
2026-07-24 08:52:39.436 | ESU6.CME [CBV] 180000 Volume #7 | Chart data loading complete.
2026-07-24 08:52:40.883 | ESU6.CME [CBV] 2500 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:52:41.127 | ESU6.CME [CBV] 2500 Volume #3 | Chart data loading complete.
2026-07-24 08:53:48.949 | MESU26_FUT_CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 08:53:48.949 | MESU26_FUT_CME [CBV] 100000 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:48.949 | MESU26_FUT_CME [CBV] 100000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:48.996 | MESU26_FUT_CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 08:53:48.996 | MESU26_FUT_CME [CBV] 180000 Volume #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:48.996 | MESU26_FUT_CME [CBV] 180000 Volume #2 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.036 | MESU26_FUT_CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 08:53:49.036 | MESU26_FUT_CME [CBV] 540000 Volume #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:49.036 | MESU26_FUT_CME [CBV] 540000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.077 | MESU26_FUT_CME [CBV] Daily #4 | Reloading chart.
2026-07-24 08:53:49.077 | MESU26_FUT_CME [CBV] Daily #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:49.077 | MESU26_FUT_CME [CBV] Daily #4 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.124 | MESU26_FUT_CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 08:53:49.124 | MESU26_FUT_CME [CBV] 3000 Volume #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:49.124 | MESU26_FUT_CME [CBV] 3000 Volume #5 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.164 | MESU26_FUT_CME Renko 6t #6 | Reloading chart.
2026-07-24 08:53:49.199 | MESU26_FUT_CME [CBV] #7 | Reloading chart.
2026-07-24 08:53:49.199 | MESU26_FUT_CME [CBV] #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:49.199 | MESU26_FUT_CME [CBV] #7 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.242 | MESU26_FUT_CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 08:53:49.242 | MESU26_FUT_CME [CBV] 2500 Volume #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2026-07-24 08:53:49.242 | MESU26_FUT_CME [CBV] 2500 Volume #8 | There are no continuous futures contract symbols. Loading data normally.
2026-07-24 08:53:49.475 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.475 | Restarting the loading process.
2026-07-24 08:53:49.477 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.477 | Restarting the loading process.
2026-07-24 08:53:49.510 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.510 | Restarting the loading process.
2026-07-24 08:53:49.531 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.531 | Restarting the loading process.
2026-07-24 08:53:49.533 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.533 | Restarting the loading process.
2026-07-24 08:53:49.535 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.535 | Restarting the loading process.
2026-07-24 08:53:49.538 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.538 | Restarting the loading process.
2026-07-24 08:53:49.539 | Repeating the loading process because the chart parameters changed.
2026-07-24 08:53:49.539 | Restarting the loading process.
2026-07-24 08:53:49.553 | MESU6.CME [CBV-D] Daily #4 | Chart data loading complete.
2026-07-24 08:53:49.587 | MESU6.CME [CBV-D] 100000 Volume #1 | Reloading chart.
2026-07-24 08:53:49.700 | Restarting the loading process.
2026-07-24 08:53:49.703 | MESU6.CME [CBV-D] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:49.705 | MESU6.CME [CBV-D] 3000 Volume #5 | Chart data loading complete.
2026-07-24 08:53:49.712 | MESU6.CME [CBV-D] 540000 Volume #3 | Chart data loading complete.
2026-07-24 08:53:49.716 | MESU6.CME [CBV-D] 180000 Volume #2 | Chart data loading complete.
2026-07-24 08:53:49.718 | MESU6.CME [CBV-D] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:49.747 | MESU6.CME [CBV-D] 2500 Volume #8 | Chart data loading complete.
2026-07-24 08:53:49.801 | MESU6.CME [CBV-D] #7 | Chart data loading complete.
2026-07-24 08:53:49.811 | MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:49.946 | MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 08:53:50.075 | MESU6.CME [CBV-D] 180000 Volume #2 | Reloading chart.
2026-07-24 08:53:50.188 | MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 08:53:50.193 | MESU6.CME [CBV-D] 540000 Volume #3 | Reloading chart.
2026-07-24 08:53:50.321 | MESU6.CME [CBV-D] Daily #4 | Reloading chart.
2026-07-24 08:53:50.782 | MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 08:53:50.784 | MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 08:53:50.788 | MESU6.CME [CBV-D] 3000 Volume #5 | Reloading chart.
2026-07-24 08:53:50.907 | MESU6.CME [CBV] Daily #4 | Chart data loading complete.
2026-07-24 08:53:50.916 | MESU6.CME Renko 6t #6 | Reloading chart.
2026-07-24 08:53:50.921 | MESU6.CME [CBV-D] #7 | Reloading chart.
2026-07-24 08:53:51.031 | MESU6.CME [CBV-D] 2500 Volume #8 | Reloading chart.
2026-07-24 08:53:51.113 | MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:51.129 | MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 08:53:51.144 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:51.147 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 08:53:51.237 | MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:53:51.414 | MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 08:53:51.584 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 08:54:00.337 | MESU6.CME [CBV] Daily #4 | Reloading chart.
2026-07-24 08:54:00.736 | MESU6.CME [CBV] Daily #4 | Chart data loading complete.
2026-07-24 08:56:04.900 | Saved Chartbook: ES500 New.Cht. Time: 0.0096 seconds.
2026-07-24 08:56:07.940 | Saved Chartbook: ES 500.Cht. Time: 0.0241 seconds.
2026-07-24 08:56:07.946 | Saved Chartbook: ES500 New.Cht. Time: 0.0050 seconds.
2026-07-24 08:56:32.021 | Paused 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 08:56:32.111 | Paused 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 08:56:32.204 | Paused 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 08:56:32.301 | Paused 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 08:56:32.432 | Paused 2.00X: MESU6.CME Renko 6t #6 | Reloading chart.
2026-07-24 08:56:32.436 | Paused 2.00X: MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 08:56:32.570 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 08:56:32.617 | Paused 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 08:56:32.619 | Paused 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 08:56:32.621 | Paused 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 08:56:32.623 | Paused 2.00X: MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:56:32.650 | Paused 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 08:56:32.652 | Paused 2.00X: MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:56:32.761 | Paused 2.00X: MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 08:56:32.774 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 08:56:32.836 | Paused 2.00X: MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:27.361 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:30:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:31:08.000
2026-07-24 08:57:28.193 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.193 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.193 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.193 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.195 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.195 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:57:28.195 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:31:09.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:32:09.000
2026-07-24 08:58:17.785 | Paused 2.00X: MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.586 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:32.587 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:32:38.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:33:38.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:42.497 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:33:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:34:57.000
2026-07-24 08:59:43.146 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.146 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.146 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.146 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.146 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.147 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.147 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:34:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:35:57.000
2026-07-24 08:59:43.825 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.825 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.825 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.826 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.826 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.826 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:43.826 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:35:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:36:58.000
2026-07-24 08:59:51.944 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.944 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.944 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.944 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.945 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.945 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:51.945 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:37:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:38:13.000
2026-07-24 08:59:55.697 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.697 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.698 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.698 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.698 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.698 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:55.698 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:38:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:39:20.000
2026-07-24 08:59:56.584 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.584 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.584 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.584 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.584 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.585 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:56.585 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:39:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:40:21.000
2026-07-24 08:59:57.392 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.392 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.392 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.392 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.392 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.393 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:57.393 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:40:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:41:21.000
2026-07-24 08:59:58.336 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.336 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.337 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.337 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.337 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.337 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 08:59:58.337 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:41:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:42:22.000
2026-07-24 09:00:16.784 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.784 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.784 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.784 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.784 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.785 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:16.785 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:42:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:43:58.000
2026-07-24 09:00:17.792 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.792 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.792 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.794 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.794 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.794 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:17.794 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:43:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:44:59.000
2026-07-24 09:00:19.424 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.424 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.424 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.426 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.426 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.426 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:19.426 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:45:01.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:46:01.000
2026-07-24 09:00:33.856 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:33.859 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:46:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:47:29.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:34.584 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:47:30.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:48:30.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:45.967 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:48:52.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:49:52.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:47.320 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:49:54.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:50:54.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:48.530 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:50:55.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:51:55.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:58.483 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:52:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:53:14.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:00:59.715 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:53:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:54:16.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:01.424 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:54:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:55:19.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.385 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:02.386 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:55:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:56:20.000
2026-07-24 09:01:03.128 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.128 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.128 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.129 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.129 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.129 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.129 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:56:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:57:21.000
2026-07-24 09:01:03.560 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.560 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.560 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.560 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.561 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.561 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.561 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:57:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:58:21.000
2026-07-24 09:01:03.800 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.800 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.800 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.800 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.800 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.801 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:03.801 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:58:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 09:59:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.187 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.401 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.402 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 09:59:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:00:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.616 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.817 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.817 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.817 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.818 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.818 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.818 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.818 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:00:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:01:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:04.996 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.176 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.176 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.176 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.176 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.176 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.177 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.177 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:01:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:02:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.386 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:05.601 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:02:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:03:21.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:08.712 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:03:27.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:04:27.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:09.648 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:04:28.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:05:28.000
2026-07-24 09:01:10.489 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:10.490 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:05:29.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:06:29.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:11.528 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:06:31.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:07:31.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.752 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:20.753 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:07:48.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:08:48.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:21.704 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:08:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:09:49.000
2026-07-24 09:01:22.448 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.448 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.448 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.448 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.448 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.449 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:22.449 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:09:49.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:10:49.000
2026-07-24 09:01:35.087 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.088 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:11:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:12:13.000
2026-07-24 09:01:35.672 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.672 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.673 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.673 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.673 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.673 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:35.673 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:12:13.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:13:13.000
2026-07-24 09:01:36.551 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.551 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.551 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.552 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.552 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.552 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:36.552 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:13:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:14:14.000
2026-07-24 09:01:37.647 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:37.648 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:14:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:15:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.112 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:15:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:16:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.422 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.672 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.672 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.672 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.672 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.672 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.673 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.673 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:16:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:17:15.000
2026-07-24 09:01:38.960 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.960 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.960 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.960 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.960 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.961 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:38.961 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:17:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:18:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.312 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.576 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.576 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.576 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.577 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.577 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.577 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.577 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:18:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:19:15.000
2026-07-24 09:01:39.872 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.872 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.873 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.873 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.873 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.873 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:39.873 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:19:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:20:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.216 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.217 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:20:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:21:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.472 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.712 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.713 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:21:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:22:15.000
2026-07-24 09:01:40.944 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.944 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.944 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.944 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.945 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.945 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:40.945 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.176 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.176 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.176 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.176 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.177 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.177 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.177 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:22:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:23:15.000
2026-07-24 09:01:41.465 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.465 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.465 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.466 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.466 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.466 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:41.466 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:23:15.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:24:15.000
2026-07-24 09:01:42.128 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.129 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.392 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.392 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.392 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.392 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.393 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.393 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.394 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:24:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:25:16.000
2026-07-24 09:01:42.649 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:42.650 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:25:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:26:16.000
2026-07-24 09:01:43.008 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.008 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.008 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.008 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.008 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.009 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.009 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:26:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:27:16.000
2026-07-24 09:01:43.312 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.312 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.312 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.313 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.313 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.313 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.313 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.544 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.544 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.544 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.544 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.544 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.545 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.545 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:27:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:28:16.000
2026-07-24 09:01:43.744 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.744 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.744 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.745 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.745 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.745 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.745 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:43.984 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:28:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:29:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:44.760 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:29:16.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:30:16.000
2026-07-24 09:01:46.144 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.144 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.144 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.145 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.145 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.145 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:46.145 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:30:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:31:18.000
2026-07-24 09:01:47.233 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:47.234 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:31:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:32:19.000
2026-07-24 09:01:48.352 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.352 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.352 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.353 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.353 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.353 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:48.353 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:32:20.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:33:20.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:49.040 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:33:21.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:34:21.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:01:50.072 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:34:22.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:35:22.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:00.944 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:35:43.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:36:43.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:01.680 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:36:44.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:37:44.000
2026-07-24 09:02:03.073 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.073 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.073 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.074 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.074 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.074 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:03.074 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:37:46.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:38:46.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:08.851 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:38:57.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:39:57.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:09.936 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:39:58.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:40:58.000
2026-07-24 09:02:11.512 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:11.513 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:41:00.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:42:00.000
2026-07-24 09:02:41.511 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:41.512 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:42:59.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:43:59.000
2026-07-24 09:02:51.336 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.336 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.336 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.336 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.336 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.337 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:51.337 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:44:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:45:18.000
2026-07-24 09:02:52.063 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.063 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.064 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.064 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.064 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.064 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.064 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:45:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:46:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:52.576 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:46:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:47:19.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:54.827 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:47:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:48:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:02:55.520 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:48:23.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:49:23.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:09.656 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:49:50.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:50:50.000
2026-07-24 09:03:10.337 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.337 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.338 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.338 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.338 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.338 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:10.338 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:50:51.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:51:51.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:16.765 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:52:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:53:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:17.480 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:53:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:54:03.000
2026-07-24 09:03:18.039 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.039 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.040 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.040 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.040 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.040 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.040 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:54:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:55:03.000
2026-07-24 09:03:18.663 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.665 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.665 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.665 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.665 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.666 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:18.666 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:55:03.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:56:03.000
2026-07-24 09:03:19.249 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.249 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.249 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.250 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.250 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.250 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:19.250 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:56:04.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:57:04.000
2026-07-24 09:03:21.503 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.503 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.503 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.503 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.504 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.504 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:21.504 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:57:07.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:58:07.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:22.151 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:58:08.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 10:59:08.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:23.504 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 10:59:10.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:00:10.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.192 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:00:11.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:01:11.000
2026-07-24 09:03:24.975 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.975 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.975 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.976 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.976 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.976 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:24.976 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:01:12.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:02:12.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:26.401 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:02:14.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:03:14.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:28.689 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:03:18.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:04:18.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:29.408 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:04:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:05:19.000
2026-07-24 09:03:30.103 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.103 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.103 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.104 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.104 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.104 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.104 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:05:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:06:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] 100000 Volume #1 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] 180000 Volume #2 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] 540000 Volume #3 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] 3000 Volume #5 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME Renko 6t #6 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] #7 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:30.579 | Replay 2.00X: MESU6.CME [CBV] 2500 Volume #8 | Replay jump | LastLoadedDateTime=2026-07-23 11:06:19.000. JumpTimeValue=1m. ReplayChartStartDateTime=2026-07-23 11:07:19.000
2026-07-24 09:03:35.802 | MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 09:03:35.892 | MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 09:03:35.982 | MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 09:03:36.086 | MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 09:03:36.205 | MESU6.CME Renko 6t #6 | Reloading chart.
2026-07-24 09:03:36.213 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:03:36.349 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:03:36.386 | MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 09:03:36.388 | MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 09:03:36.390 | MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:03:36.436 | MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 09:03:36.439 | MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 09:03:36.476 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:03:36.517 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 09:03:36.520 | MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:03:36.593 | MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 09:03:36.702 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 09:18:22.647 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:18:23.061 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 09:19:22.948 | Starting downloads for all open Historical Daily data charts.
2026-07-24 09:19:22.950 | Added historical Daily data request for ESU6.CME to the queue.
2026-07-24 09:19:22.950 | Triggering next historical data download in queue.
2026-07-24 09:19:22.950 | Added historical Daily data request for MESU6.CME to the queue.
2026-07-24 09:19:22.952 | HD Request # 17 | Downloading Historical Daily chart data for ESU6.CME. Starting date: 2026-07-22. Service: rithmic.trading
2026-07-24 09:19:24.132 | HD Request # 17 | Requesting historical Daily data for ESU26 starting at 2026-07-21. SC External HD service.
2026-07-24 09:19:25.346 | HD Request # 17 | Receiving historical Daily data for ESU6.CME starting at 2026-07-22.
2026-07-24 09:19:25.346 | HD Request # 17 | Writing historical Daily data to the file ESU6.CME.dly.
2026-07-24 09:19:25.352 | HD Request # 17 | Bytes received: 232
2026-07-24 09:19:25.352 | HD Request # 17 | Received 4 Daily data records from 2026-07-22 00:00:00 to 2026-07-24 00:00:00 (3.0 days) and wrote 3 records for ESU6.CME
2026-07-24 09:19:25.352 | HD Request # 17 | Completion time: 3s.
2026-07-24 09:19:25.352 | HD Request # 17 | Daily data download complete for ESU6.CME. Unique request ID: 17
2026-07-24 09:19:25.352 | Removing historical data download ID 17.
2026-07-24 09:19:25.353 | Triggering next historical data download in queue.
2026-07-24 09:19:25.355 | HD Request # 18 | Downloading Historical Daily chart data for MESU6.CME. Starting date: 2026-07-22. Service: rithmic.trading
2026-07-24 09:19:25.557 | ESU6.CME [CBV] Daily #5 | Reloading chart.
2026-07-24 09:19:25.859 | ESU6.CME [CBV] Daily #5 | Chart data loading complete.
2026-07-24 09:19:26.704 | HD Request # 18 | Requesting historical Daily data for ETU26 starting at 2026-07-21. SC External HD service.
2026-07-24 09:19:27.928 | HD Request # 18 | Receiving historical Daily data for MESU6.CME starting at 2026-07-22.
2026-07-24 09:19:27.928 | HD Request # 18 | Writing historical Daily data to the file MESU6.CME.dly.
2026-07-24 09:19:27.929 | HD Request # 18 | Bytes received: 229
2026-07-24 09:19:27.929 | HD Request # 18 | Received 4 Daily data records from 2026-07-22 00:00:00 to 2026-07-24 00:00:00 (3.0 days) and wrote 3 records for MESU6.CME
2026-07-24 09:19:27.929 | HD Request # 18 | Completion time: 2s.
2026-07-24 09:19:27.929 | HD Request # 18 | Daily data download complete for MESU6.CME. Unique request ID: 18
2026-07-24 09:19:27.929 | Removing historical data download ID 18.
2026-07-24 09:19:27.929 | No download requests in the queue to start downloads for.
2026-07-24 09:19:27.977 | MESU6.CME [CBV] Daily #4 | Reloading chart.
2026-07-24 09:19:28.351 | MESU6.CME [CBV] Daily #4 | Chart data loading complete.
2026-07-24 09:19:40.457 | Saved Chartbook: ES500 New.Cht. Time: 0.0113 seconds.
2026-07-24 09:21:01.390 | Reloading all Intraday charts in active chartbook.
2026-07-24 09:21:01.428 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:21:01.531 | MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 09:21:01.685 | MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 09:21:01.797 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:21:01.853 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 09:21:01.866 | MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 09:21:01.956 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:21:01.975 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 09:21:01.977 | MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 09:21:02.000 | MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 09:21:02.072 | MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 09:21:02.098 | MESU6.CME Renko 6t #6 | Reloading chart.
2026-07-24 09:21:02.173 | MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 09:21:02.180 | MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:21:02.207 | MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 09:21:02.294 | MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:21:02.374 | MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 09:22:37.474 | File >> Disconnect selected.
2026-07-24 09:22:37.475 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2026-07-24 09:22:37.478 | DTC Client socket (2) | CloseSocket call.
2026-07-24 09:22:37.478 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-07-24 09:22:37.479 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2026-07-24 09:22:37.493 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2026-07-24 09:22:37.496 | DTC Client socket (1) | CloseSocket call.
2026-07-24 09:22:37.496 | DTC Client socket (1) | Max send buffers used during socket life: 3
2026-07-24 09:22:37.496 | DTC Client socket (1) | Max send buffer size during socket life: 406
2026-07-24 09:22:37.496 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-07-24 09:22:37.514 | SC Data with Depth | Waiting for socket receive thread to end
2026-07-24 09:22:37.516 | DTC Client socket (4) | CloseSocket call.
2026-07-24 09:22:37.516 | DTC Client socket (4) | Max send buffers used during socket life: 3
2026-07-24 09:22:37.516 | DTC Client socket (4) | Max send buffer size during socket life: 354
2026-07-24 09:22:37.516 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-07-24 09:22:37.517 | SC Data with Depth | Disconnected from the server.
2026-07-24 09:22:37.518 | Delayed Data Feed | Waiting for socket receive thread to end
2026-07-24 09:22:37.520 | DTC Client socket (5) | CloseSocket call.
2026-07-24 09:22:37.520 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2026-07-24 09:22:37.520 | Delayed Data Feed | Disconnected from the server.
2026-07-24 09:22:37.520 | Rithmic Direct - DTC | Disconnected.
2026-07-24 09:22:37.696 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-07-24 09:22:37.696 | DTC Client socket (2) | Closed.
2026-07-24 09:22:37.715 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-07-24 09:22:37.715 | DTC Client socket (1) | Closed.
2026-07-24 09:22:37.759 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-07-24 09:22:37.759 | DTC Client socket (5) | Closed.
2026-07-24 09:22:37.761 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-07-24 09:22:37.761 | DTC Client socket (4) | Closed.
2026-07-24 09:23:19.017 |
2026-07-24 09:23:19.019 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated
2026-07-24 09:23:19.020 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2026-07-24 09:23:19.022 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2026-07-24 09:23:19.348 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-07-24 09:23:19.348 | DTC Client socket (1) | New receive buffer size: 0
2026-07-24 09:23:19.348 | DTC Client socket (1) | Connecting to IP: 208.97.247.100.
2026-07-24 09:23:19.611 | Rithmic Direct - DTC | Network connection to server complete.
2026-07-24 09:23:19.611 | Rithmic Direct - DTC | Starting socket receive thread.
2026-07-24 09:23:19.612 | Rithmic Direct - DTC | Using fixed encoding of Binary
2026-07-24 09:23:19.612 | Rithmic Direct - DTC | Sending logon request message.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Received logon response.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Server Name: .
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Successfully connected.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Trading is supported.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Order cancel and replace is supported.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | OCO Orders supported.
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2026-07-24 09:23:20.421 | Rithmic Direct - DTC | Connection to server complete.
2026-07-24 09:23:20.437 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-07-24 09:23:20.438 | Subscribing to symbol for symbol alert. ZNM4.CBOT
2026-07-24 09:23:20.438 | Using symbol data fast lookup vector
2026-07-24 09:23:20.438 | Rithmic Direct - DTC | Starting real-time market data updates for: ZNM4.CBOT. ID: 1 Service code: rithmic.trading
2026-07-24 09:23:20.439 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50531
2026-07-24 09:23:20.439 | Rithmic Direct - DTC | Requesting security definition data for: ZNM4.CBOT. ID: 1
2026-07-24 09:23:20.439 | Subscribing to symbol for symbol alert. CLG4.NYMEX
2026-07-24 09:23:20.439 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2026-07-24 09:23:20.440 | Rithmic Direct - DTC | Starting real-time market data updates for: CLG4.NYMEX. ID: 2 Service code: rithmic.trading
2026-07-24 09:23:20.440 | Rithmic Direct - DTC | Requesting security definition data for: CLG4.NYMEX. ID: 2
2026-07-24 09:23:20.440 | DTC Client socket (2) | New receive buffer size: 0
2026-07-24 09:23:20.440 | DTC Client socket (2) | Connecting to IP: 208.97.247.100.
2026-07-24 09:23:20.440 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees.
2026-07-24 09:23:20.496 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU6.CME. ID: 3 Service code: rithmic.trading
2026-07-24 09:23:20.496 | Rithmic Direct - DTC | Requesting security definition data for: ESU6.CME. ID: 3
2026-07-24 09:23:20.496 | Added historical Intraday data request for ESU6.CME to the queue.
2026-07-24 09:23:20.496 | Intraday data recording state for symbol ESU6.CME is set to download 'Pending'.
2026-07-24 09:23:20.496 | Triggering next historical data download in queue.
2026-07-24 09:23:20.497 | Delaying start of download for ESU6.CME.
2026-07-24 09:23:20.497 | Rithmic Direct - DTC | Starting real-time market data updates for: MESU6.CME. ID: 4 Service code: rithmic.trading
2026-07-24 09:23:20.497 | Rithmic Direct - DTC | Requesting security definition data for: MESU6.CME. ID: 4
2026-07-24 09:23:20.497 | Added historical Intraday data request for MESU6.CME to the queue.
2026-07-24 09:23:20.497 | Intraday data recording state for symbol MESU6.CME is set to download 'Pending'.
2026-07-24 09:23:20.497 | Triggering next historical data download in queue.
2026-07-24 09:23:20.697 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2026-07-24 09:23:20.697 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2026-07-24 09:23:20.697 | Rithmic Direct - DTC (Data) | Using fixed encoding of Binary
2026-07-24 09:23:20.697 | Rithmic Direct - DTC (Data) | Sending logon request message.
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Received logon response.
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Server Name: .
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Successfully connected.
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Trading is not supported.
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLG4.NYMEX
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESU6.CME
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MESU6.CME
2026-07-24 09:23:21.509 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ZNM4.CBOT
2026-07-24 09:23:21.803 | Rithmic Direct - DTC (Data) | Received security definition for symbol ESU6.CME
2026-07-24 09:23:21.803 | Rithmic Direct - DTC (Data) | Received security definition for symbol MESU6.CME
2026-07-24 09:23:26.119 | HD Request # 19 | Downloading Intraday chart data for ESU6.CME to the file ESU6.CME.scid. Service: rithmic.trading
2026-07-24 09:23:26.119 | HD Request # 19 | Download start date-time: 2026-07-24 09:22:38.000000. File last date-time: 2026-07-24 09:22:38.000000
2026-07-24 09:23:26.123 | HD Request # 19 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 09:23:26.123 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 09:23:26.124 | Socket (3) | New receive buffer size: 0
2026-07-24 09:23:26.124 | Socket (3) | Connecting to IP: 208.97.247.100.
2026-07-24 09:23:26.382 | HD Request # 19 | Sending historical data logon request message.
2026-07-24 09:23:27.162 | HD Request # 19 | Requesting Intraday data. Start date-time: 2026-07-24 09:22:38. Record interval: 1. Symbol: ESU6.CME
2026-07-24 09:23:27.423 | HD Request # 19 | Receiving Intraday data for ESU6.CME starting at 2026-07-24 09:22:39.000000
2026-07-24 09:23:27.677 | Socket (3) | CloseSocket call.
2026-07-24 09:23:27.677 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 09:23:27.678 | Historical data download thread signaled to stop.
2026-07-24 09:23:27.678 | HD Request # 19 | Timestamp of first Intraday data file record written: 2026-07-24 09:22:39.000000.
2026-07-24 09:23:27.678 | HD Request # 19 | Received 19 Intraday data records from 2026-07-24 09:22:39.000000 to 2026-07-24 09:23:28.000000 (49.0 seconds. Delay: -0.3 seconds) and wrote 19 records for ESU6.CME
2026-07-24 09:23:27.679 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2026-07-24 09:23:28.000000
2026-07-24 09:23:27.680 | HD Request # 19 | Completion time: 1s.
2026-07-24 09:23:27.680 | HD Request # 19 | Intraday data download complete for ESU6.CME. Unique request ID: 19
2026-07-24 09:23:27.680 | Removing historical data download ID 19.
2026-07-24 09:23:27.680 | Real-time Intraday chart data file updates started for ESU6.CME
2026-07-24 09:23:27.681 | Opened cached Intraday file: C:\SierraChart\Data\ESU6.CME.scid. Thread ID: 6384
2026-07-24 09:23:27.681 | Intraday chart data file opened for ESU6.CME
2026-07-24 09:23:27.681 | HD Request # 19 | Enabling Intraday chart updating for symbol.
2026-07-24 09:23:27.681 | Triggering next historical data download in queue.
2026-07-24 09:23:27.681 | HD Request # 20 | Downloading Intraday chart data for MESU6.CME to the file MESU6.CME.scid. Service: rithmic.trading
2026-07-24 09:23:27.682 | HD Request # 20 | Download start date-time: 2026-07-24 09:22:38.000000. File last date-time: 2026-07-24 09:22:38.000000
2026-07-24 09:23:27.682 | HD Request # 20 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 09:23:27.682 | Socket (4) | Creating socket. Using TLS 1.2.
2026-07-24 09:23:27.683 | Socket (4) | New receive buffer size: 0
2026-07-24 09:23:27.683 | Socket (4) | Connecting to IP: 208.97.247.100.
2026-07-24 09:23:27.932 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 09:23:27.932 | Socket (3) | Closed.
2026-07-24 09:23:27.936 | HD Request # 20 | Sending historical data logon request message.
2026-07-24 09:23:28.711 | HD Request # 20 | Requesting Intraday data. Start date-time: 2026-07-24 09:22:38. Record interval: 1. Symbol: MESU6.CME
2026-07-24 09:23:28.972 | HD Request # 20 | Receiving Intraday data for MESU6.CME starting at 2026-07-24 09:22:39.000000
2026-07-24 09:23:28.987 | Socket (4) | CloseSocket call.
2026-07-24 09:23:28.987 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-07-24 09:23:28.988 | Historical data download thread signaled to stop.
2026-07-24 09:23:28.988 | HD Request # 20 | Timestamp of first Intraday data file record written: 2026-07-24 09:22:39.000000.
2026-07-24 09:23:28.988 | HD Request # 20 | Received 18 Intraday data records from 2026-07-24 09:22:39.000000 to 2026-07-24 09:23:28.000000 (49.0 seconds. Delay: 1.0 seconds) and wrote 18 records for MESU6.CME
2026-07-24 09:23:28.989 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2026-07-24 09:23:28.000000
2026-07-24 09:23:28.989 | HD Request # 20 | Completion time: 1s.
2026-07-24 09:23:28.989 | HD Request # 20 | Intraday data download complete for MESU6.CME. Unique request ID: 20
2026-07-24 09:23:28.989 | Removing historical data download ID 20.
2026-07-24 09:23:28.989 | Real-time Intraday chart data file updates started for MESU6.CME
2026-07-24 09:23:28.990 | Opened cached Intraday file: C:\SierraChart\Data\MESU6.CME.scid. Thread ID: 6384
2026-07-24 09:23:28.990 | Intraday chart data file opened for MESU6.CME
2026-07-24 09:23:28.990 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2026-07-24 09:23:28.990 | No download requests in the queue to start downloads for.
2026-07-24 09:23:29.243 | Socket (4) | Socket gracefully closed by remote side.
2026-07-24 09:23:29.244 | Socket (4) | Closed.
2026-07-24 09:23:39.218 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
2026-07-24 09:23:39.218 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0
2026-07-24 09:23:39.218 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130.
2026-07-24 09:23:40.894 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 115672
2026-07-24 09:23:40.900 | Rithmic Direct - DTC | Processed connection points. Count: 496
2026-07-24 09:23:41.161 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call.
2026-07-24 09:23:41.161 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
2026-07-24 09:23:41.399 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
2026-07-24 09:23:41.399 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed.
2026-07-24 09:30:47.614 | Source file does not exist when saving backup of C:\SierraChart\SymbolSettings\CustomSymbolSettings.rithmic_v2.trading.xml. No backup made.
2026-07-24 09:31:02.217 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:31:02.349 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:31:02.372 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 09:31:42.375 | Added historical Intraday data request for MESM6.CME to the queue.
2026-07-24 09:31:42.376 | Triggering next historical data download in queue.
2026-07-24 09:31:42.376 | Added historical Daily data request for MESM6.CME to the queue.
2026-07-24 09:31:42.377 | Added historical Intraday data request for MESU6.CME to the queue.
2026-07-24 09:31:42.377 | Intraday data recording state for symbol MESU6.CME is set to download 'Pending'.
2026-07-24 09:31:42.377 | Added historical Daily data request for MESU6.CME to the queue.
2026-07-24 09:31:42.379 | HD Request # 21 | Downloading Intraday chart data for MESM6.CME to the file MESM6.CME.scid. Service: rithmic.trading
2026-07-24 09:31:42.381 | Reloading all charts with filename: MESM6.CME.scid
2026-07-24 09:31:42.383 | HD Request # 21 | Download start date-time: 2026-03-07 00:00:00.000000. File last date-time: 00:00:00.000000
2026-07-24 09:31:42.385 | HD Request # 22 | Downloading Historical Daily chart data for MESM6.CME. Starting date: 1986-07-10. Service: rithmic.trading
2026-07-24 09:31:42.386 | HD Request # 21 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 09:31:42.387 | Socket (4) | Creating socket. Using TLS 1.2.
2026-07-24 09:31:42.387 | Socket (4) | New receive buffer size: 0
2026-07-24 09:31:42.387 | Socket (4) | Connecting to IP: 208.97.247.100.
2026-07-24 09:31:42.646 | HD Request # 21 | Sending historical data logon request message.
2026-07-24 09:31:43.422 | HD Request # 21 | Requesting Intraday data. Start date-time: 2026-03-07 00:00:00. Record interval: 1. Symbol: MESM6.CME
2026-07-24 09:31:43.561 | HD Request # 22 | Requesting historical Daily data for ETM26 starting at 1986-07-09. SC External HD service.
2026-07-24 09:31:43.688 | HD Request # 21 | Receiving Intraday data for MESM6.CME starting at 2026-03-08 22:00:10.000000
2026-07-24 09:31:44.758 | HD Request # 22 | Receiving historical Daily data for MESM6.CME starting at 2025-03-03.
2026-07-24 09:31:44.758 | HD Request # 22 | Writing historical Daily data to the file MESM6.CME.dly.
2026-07-24 09:31:44.762 | HD Request # 22 | Bytes received: 17115
2026-07-24 09:31:44.762 | HD Request # 22 | Received 328 Daily data records from 2025-03-03 00:00:00 to 2026-06-18 00:00:00 (473.0 days) and wrote 328 records for MESM6.CME
2026-07-24 09:31:44.762 | HD Request # 22 | Completion time: 2s.
2026-07-24 09:31:44.762 | HD Request # 22 | Daily data download complete for MESM6.CME. Unique request ID: 22
2026-07-24 09:31:44.762 | Removing historical data download ID 22.
2026-07-24 09:31:44.764 |
2026-07-24 09:31:44.764 | Triggering next historical data download in queue.
2026-07-24 09:31:44.764 | HD Request # 23 | Downloading Historical Daily chart data for MESU6.CME. Starting date: 1986-08-03. Service: rithmic.trading
2026-07-24 09:31:45.924 | HD Request # 23 | Requesting historical Daily data for ETU26 starting at 1986-08-02. SC External HD service.
2026-07-24 09:31:47.345 | HD Request # 23 | Receiving historical Daily data for MESU6.CME starting at 2025-06-02.
2026-07-24 09:31:47.346 | HD Request # 23 | Writing historical Daily data to the file MESU6.CME.dly.
2026-07-24 09:31:47.350 | HD Request # 23 | Bytes received: 14780
2026-07-24 09:31:47.350 | HD Request # 23 | Received 289 Daily data records from 2025-06-02 00:00:00 to 2026-07-24 00:00:00 (418.0 days) and wrote 289 records for MESU6.CME
2026-07-24 09:31:47.350 | HD Request # 23 | Completion time: 3s.
2026-07-24 09:31:47.350 | HD Request # 23 | Daily data download complete for MESU6.CME. Unique request ID: 24
2026-07-24 09:31:47.350 | Removing historical data download ID 24.
2026-07-24 09:31:47.351 |
2026-07-24 09:31:47.351 | No download requests in the queue to start downloads for.
2026-07-24 09:31:47.741 | MESU6.CME [CBV] Daily #4 | Reloading chart.
2026-07-24 09:31:48.099 | MESU6.CME [CBV] Daily #4 | Chart data loading complete.
2026-07-24 09:31:50.804 | HD Request # 21 | Timestamp of first Intraday data file record written: 2026-03-08 22:00:10.000000.
2026-07-24 09:34:11.999 | Socket (4) | CloseSocket call.
2026-07-24 09:34:12.001 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-07-24 09:34:12.005 | HD Request # 21 | Error downloading historical Intraday data for MESM6.CME. output inhibited
2026-07-24 09:34:12.005 | Historical data download thread signaled to stop.
2026-07-24 09:34:12.007 | HD Request # 21 | Received 300000 Intraday data records from 2026-03-08 22:00:10.000000 to 2026-03-19 22:16:05.000000 (11.0 days. Delay: 126.5 days) and wrote 300000 records for MESM6.CME
2026-07-24 09:34:12.011 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2026-03-19 22:16:05.000000
2026-07-24 09:34:12.011 | HD Request # 21 | Completion time: 2m 30s.
2026-07-24 09:34:12.011 | HD Request # 21 | Intraday data download complete for MESM6.CME. Unique request ID: 21
2026-07-24 09:34:12.012 | Removing historical data download ID 21.
2026-07-24 09:34:12.013 | Real-time Intraday chart data file updates started for MESM6.CME
2026-07-24 09:34:12.015 | Opened cached Intraday file: C:\SierraChart\Data\MESM6.CME.scid. Thread ID: 6384
2026-07-24 09:34:12.015 | Intraday chart data file opened for MESM6.CME
2026-07-24 09:34:12.015 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2026-07-24 09:34:12.015 | Triggering next historical data download in queue.
2026-07-24 09:34:12.016 | HD Request # 24 | Downloading Intraday chart data for MESU6.CME to the file MESU6.CME.scid. Service: rithmic.trading
2026-07-24 09:34:12.021 | Reloading all charts with filename: MESU6.CME.scid
2026-07-24 09:34:12.022 | HD Request # 24 | Download start date-time: 2026-06-06 00:00:00.000000. File last date-time: 00:00:00.000000
2026-07-24 09:34:12.024 | HD Request # 24 | Using server: rsc.rithmic.com port 50530. Use encryption.
2026-07-24 09:34:12.028 | Socket (3) | Creating socket. Using TLS 1.2.
2026-07-24 09:34:12.031 | Socket (3) | New receive buffer size: 0
2026-07-24 09:34:12.031 | Socket (3) | Connecting to IP: 208.97.247.100.
2026-07-24 09:34:12.145 | MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 09:34:12.196 | MESU6.CME [CBV] 540000 Volume #3 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.206 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:34:12.247 | MESU6.CME [CBV] #7 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.256 | Socket (4) | Socket gracefully closed by remote side.
2026-07-24 09:34:12.256 | Socket (4) | Closed.
2026-07-24 09:34:12.286 | HD Request # 24 | Sending historical data logon request message.
2026-07-24 09:34:12.300 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 09:34:12.343 | MESU6.CME [CBV] 2500 Volume #9 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.357 | MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 09:34:12.398 | MESU6.CME [CBV] 100000 Volume #1 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.410 | MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 09:34:12.451 | MESU6.CME [CBV] 3000 Volume #5 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.494 | MESU6.CME Renko 6t #6 | Reloading chart.
2026-07-24 09:34:12.508 | MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 09:34:12.550 | MESU6.CME [CBV] 180000 Volume #2 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:12.552 | MESU6.CME Renko 6t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESU6.CME.scid
2026-07-24 09:34:12.552 | MESU6.CME Renko 6t #6 | Chart data loading complete.
2026-07-24 09:34:12.557 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:34:12.570 | MESU6.CME [CBV] 2500 Volume #8 | Waiting for historical downloads to complete with the IDs: 23,
2026-07-24 09:34:13.059 | HD Request # 24 | Requesting Intraday data. Start date-time: 2026-06-06 00:00:00. Record interval: 1. Symbol: MESU6.CME
2026-07-24 09:34:13.423 | HD Request # 24 | Receiving Intraday data for MESU6.CME starting at 2026-06-07 22:00:01.000000
2026-07-24 09:34:24.324 | HD Request # 24 | Timestamp of first Intraday data file record written: 2026-06-07 22:00:01.000000.
2026-07-24 09:34:24.737 | MESU6.CME Renko 6t #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:41.070 | Socket (3) | CloseSocket call.
2026-07-24 09:35:41.070 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-07-24 09:35:41.070 | HD Request # 24 | Error downloading historical Intraday data for MESU6.CME. output inhibited
2026-07-24 09:35:41.072 | Historical data download thread signaled to stop.
2026-07-24 09:35:41.072 | HD Request # 24 | Received 199992 Intraday data records from 2026-06-07 22:00:01.000000 to 2026-06-17 00:13:51.000000 (9.1 days. Delay: 37.4 days) and wrote 199992 records for MESU6.CME
2026-07-24 09:35:41.074 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2026-06-17 00:13:51.000000
2026-07-24 09:35:41.077 | Added 512 Time and Sales records to Intraday data file for MESU6.CME after download.
2026-07-24 09:35:41.078 | HD Request # 24 | Completion time: 1m 29s.
2026-07-24 09:35:41.078 | HD Request # 24 | Intraday data download complete for MESU6.CME. Unique request ID: 23
2026-07-24 09:35:41.078 | Removing historical data download ID 23.
2026-07-24 09:35:41.078 | Real-time Intraday chart data file updates started for MESU6.CME
2026-07-24 09:35:41.079 | Opened cached Intraday file: C:\SierraChart\Data\MESU6.CME.scid. Thread ID: 6384
2026-07-24 09:35:41.079 | Intraday chart data file opened for MESU6.CME
2026-07-24 09:35:41.079 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2026-07-24 09:35:41.079 | No download requests in the queue to start downloads for.
2026-07-24 09:35:41.106 | MESU6.CME [CBV] 3000 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.108 | MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 09:35:41.165 | MESU6.CME [CBV] 180000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.166 | MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 09:35:41.218 | MESU6.CME [CBV] 2500 Volume #8 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.219 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:35:41.238 | MESU6.CME [CBV] 540000 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.239 | MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 09:35:41.284 | MESU6.CME [CBV] #7 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.285 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:35:41.324 | Socket (3) | Socket gracefully closed by remote side.
2026-07-24 09:35:41.324 | Socket (3) | Closed.
2026-07-24 09:35:41.338 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:41.432 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 09:35:41.514 | MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:41.548 | MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 09:35:41.578 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 09:35:41.637 | MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 09:35:41.639 | MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 09:35:41.639 | MESU6.CME [CBV] 2500 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.640 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 09:35:41.668 | MESU6.CME [CBV] 100000 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load.
2026-07-24 09:35:41.669 | MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 09:35:41.697 | MESU6.CME [CBV] 3000 Volume #5 | Reloading chart.
2026-07-24 09:35:41.807 | MESU6.CME [CBV] 180000 Volume #2 | Reloading chart.
2026-07-24 09:35:41.889 | MESU6.CME [CBV] 3000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:41.941 | MESU6.CME [CBV] 3000 Volume #5 | Chart data loading complete.
2026-07-24 09:35:41.985 | MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 09:35:41.989 | MESU6.CME [CBV] 2500 Volume #8 | Reloading chart.
2026-07-24 09:35:42.029 | MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:42.047 | MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
2026-07-24 09:35:42.062 | MESU6.CME [CBV] 540000 Volume #3 | Reloading chart.
2026-07-24 09:35:42.136 | MESU6.CME [CBV] 2500 Volume #8 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:42.194 | MESU6.CME [CBV] 2500 Volume #8 | Chart data loading complete.
2026-07-24 09:35:42.208 | MESU6.CME [CBV] 180000 Volume #2 | Chart data loading complete.
2026-07-24 09:35:42.281 | MESU6.CME [CBV] #7 | Reloading chart.
2026-07-24 09:35:42.361 | MESU6.CME [CBV] 540000 Volume #3 | Chart data loading complete.
2026-07-24 09:35:42.368 | MESU6.CME [CBV] 2500 Volume #9 | Reloading chart.
2026-07-24 09:35:42.444 | MESU6.CME [CBV] 100000 Volume #1 | Reloading chart.
2026-07-24 09:35:42.538 | MESU6.CME [CBV] #7 | Chart data loading complete.
2026-07-24 09:35:42.724 | MESU6.CME [CBV] 100000 Volume #1 | Chart data loading complete.
2026-07-24 09:35:42.729 | MESU6.CME [CBV] 2500 Volume #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2026-07-24 09:35:42.739 | MESU6.CME [CBV] 2500 Volume #9 | Chart data loading complete.
[2026-07-24 14:48:42]
John - SC Support - Posts: 48317
You are getting your data from Rithmic. They have a lack of historical data available, so any missing data is going to continue to be missing. You will not be able to get it back when using Rithmic's data. Refer to the following:
Rithmic Trading Platform Service: Rithmic Support Policy
