Date/Time: Fri, 23 Oct 2026 02:19:36 +0000
Renko whow to change periodsarb
View Count: 225
| [2026-07-23 11:53:42] |
| User360283 - Posts: 538 |
I cant find this Please where is it now Thanks |
| [2026-07-23 15:25:12] |
| John - SC Support - Posts: 48303 |
The choice of which Renko to use is selected in "Chart >> Chart Settings >> Bar Period Type". Then the particular parameters that are needed for the chosen Renko type are entered in the field below that for "Bar Period Value". Refer to the following and the item below it: Chart Settings: Bar Period Type (List) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
