Date/Time: Mon, 26 Oct 2026 03:13:07 +0000
Is it possible to set a Reverse at Stop Loss?
View Count: 321
| [2026-07-22 22:38:48] |
| User728422 - Posts: 4 |
Is it possible to set a Reverse at Stop Loss to trigger a new order in the opposite direction when the stop loss is hit? To have an option on Targets when setting up a Stop Loss to be able to chose a Reverse option if needed? I've done it trading on Ninjatrader. Thank you, Jeff |
| [2026-07-22 23:03:41] |
Also 2 more questions: 1. How to change DOM Last Size column background? 2. Is there a filter on DOM Last Size column? Thank you, Jeff |
| [2026-07-23 13:12:37] |
| John - SC Support - Posts: 48317 |
Sierra Chart is setup to ensure that the quantities of the Targets and Stops match the quantity of the parent order. Therefore, it is not possible to have an initial attached order that would exceed the quantity in order to have an automatic reversal. To do this, you would need to send a separate Stop-Limit order at the same price as your attached stop, so that it will fill when that price is reached. This also gives you the advantage of being able to set attached orders to that Stop-Limit. 1. How to change DOM Last Size column background?
There is not an option for this. 2. Is there a filter on DOM Last Size column?
There is no filter available for the Last Size column. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-23 13:24:51
| [2026-07-26 22:58:51] |
-- "Sierra Chart is setup to ensure that the quantities of the Targets and Stops match the quantity of the parent order. Therefore, it is not possible to have an initial attached order that would exceed the quantity in order to have an automatic reversal. To do this, you would need to send a separate Stop-Limit order at the same price as your attached stop, so that it will fill when that price is reached. This also gives you the advantage of being able to set attached orders to that Stop-Limit." -- The way it could be done is - by checking a check box added to the target to reverse at the stop loss, the logic would simply place a Stop-Limit order at the same or 1-2 ticks above/below price where attached stop is. Same thing that you suggested, only instead of doing it manually the system will do it programmatically. Thank you, Jeff |
