Date/Time: Fri, 23 Oct 2026 02:16:21 +0000
Questions to the historical accuracy of tick data
View Count: 411
| [2026-07-22 22:22:11] |
| zzzieke - Posts: 1 |
I’m using the Sierra Chart Historical Data Service for CME futures (NQ) tick data for backtesting. A few questions about data provenance and quality: 1. Is the historical CME intraday data sourced directly from CME’s MDP 3.0 feed? 2. Is the bid/ask volume in historical CME records exchange-reported (from the MDP 3.0 aggressor flag), or inferred by a tick rule? 3. How are CME summary/unbundled trades represented in the .scid files? 4. For NQ, how far back is genuine tick-by-tick data available, and is there a cutoff before which it’s aggregated rather than true tick? Thanks |
| [2026-07-24 05:46:08] |
| Sierra_Chart Engineering - Posts: 25248 |
Refer to: Sierra Chart Historical Data Service: CME Group Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
