Date/Time: Fri, 23 Oct 2026 02:17:13 +0000
What service packages would I need for each of these options?
View Count: 536
[2026-07-21 09:09:42]
User891371 - Posts: 1
1. I just want to use the big trades indicator. I don’t think CME Level 2 data is necessary for this indicator. Which Sierra Charts package do I need? Do I need CME Level 2 data? 2. If I wanted to view the DOM and liquidity, which Sierra Charts package do I need? Do I need CME Level 2 data? Thank you
Date Time Of Last Edit: 2026-07-21 09:14:22
[2026-07-21 14:14:35]
John - SC Support - Posts: 48303
The "Large Volume Trade Indicator" is available with any package.
You do not need the Level 2 data to use the Large Volume Trade Indicator. It works off the actual traded data, not the market depth data.
If you are wanting to get real-time data and/or connect to a trading service, then you will need to be on one of the "Integrated" packages. In this case, the lowest cost option is the "Integrated Standard" package. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing: Packages
To change to a paid package, follow these instructions:
Sierra Chart Purchase and License Information: Instructions
