Date/Time: Tue, 20 Oct 2026 19:08:09 +0000
Coloring Every 10th Volume Bar White
View Count: 241
[2026-07-21 03:11:25]
User619465 - Posts: 12
Greetings,
I'm trying to figure out how to color every 10th Volume Bar... white (not the background)
I've added a "Bar Numbering" study
Set it to 10
Set the Chart region to 2 (same as the Volume)
This works and numbers every 10th volume bar
Then I add a "Color Bar Based on Alert Condition) study
Create an alert condition referencing the "Bar Numbering" study
Set the "Color Bar Based on Alert Condition" to Region 2
Nothing happens
side note
I can do above with "Color Background Based On Alert Condition" - It works fine
However I want to color specific Volume Bars, not the background thereof, based on their Bar Number
Thank you
[2026-07-21 13:56:44]
Sawtooth - Posts: 4357
Here's how to do it:
Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies
[2026-07-21 21:30:53]
That worked!!
Thank You
