Date/Time: Tue, 20 Oct 2026 00:50:13 +0000
MBO blocks not displaying for ZN/ZB symbols
View Count: 230
[2026-07-20 11:58:58]
User842713 - Posts: 1
I have Denali Feed subscription Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional Trading accounts.
I also have SP 12.
This is main instance, no subinstances.
I'm having issues visualising MBO bars specifically for CBOT symbols such as ZB/ZN.
I can see them okay on ES - https://snipboard.io/RmjLxp.jpg
However, on ZN they do not visualise - https://snipboard.io/06mwpj.jpg
These screenshots are from the same chartbook. So my global server settings should be okay. I should have Market Depth for CBOT symbols as well.
I checked the threads for similar issues, I searched online, I went all over the settings. I'm at a loss why they do not visualize.
Can you help in finding out what the issue might be?
What settings should I provide for you to verify?
[2026-07-20 14:50:20]
John - SC Support - Posts: 48259
You are using a third-party study to display the MBO data, so you would need to ask the developer of that study about this.
If you are having displaying the MBO data using the built-in Sierra Chart tools (i.e. not using a third-party study), then let us know.
