Date/Time: Fri, 23 Oct 2026 22:36:56 +0000
Bid & Ask Depth Bars Study / SG4 draw style not saving
View Count: 199
[2026-07-20 03:34:34]
ChrisK - Posts: 53
Good evening,
I’m currently on version 2926. I noticed when using Bid & Ask Depth Bars on ES with study calculation mode set to Bid Depth vs Ask Depth, I set subgraph SG4 (Difference) draw style to Bar, but it seems SC always reverts SG4’s draw style back to Line when I reopen the chart even after saving the setting as Bar.
Do you see this issue on your end?
Thank you.
[2026-07-20 03:54:23]
Sierra_Chart Engineering - Posts: 25251
We are checking on this.
[2026-07-20 03:57:26]
To solve this problem, open the Study Settings for that instance of the study on the chart and set this Input to No:
Automatically Set Draw Styles
[2026-07-20 04:02:15]
ChrisK - Posts: 53
Will do, thank you for pointing that out to me.
