Date/Time: Tue, 27 Oct 2026 18:33:24 +0000
[Programming Help] - Line Label LL_DISPLAY_NAME
View Count: 307
| [2026-07-19 19:35:42] |
| User92573 - Posts: 621 |
Dear Support, Apologies for such a simple question. I'm not sure why the following doesn't Check-the-box for "Name Label" and set Subgraph "Line Label" to Name? Subgraph_Low.LineLabel = LL_DISPLAY_NAME | LL_NAME_ALIGN_RIGHT;
Any help appreciated. |
| [2026-07-28 15:35:28] |
| John - SC Support - Posts: 48342 |
We did a quick test for this and it is working properly for us. The "Name Label" option is checked and the label is set to a Horizontal Alignment of "Right". Note that "LL_DISPLAY_NAME" is the option to enable the "Name Label". We are not understanding what you mean by "set Subgraph "Line Label" to Name". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-28 16:58:57] |
Coming back to such a powerful platform and programming language like ACSIL can be a real re-learning curve. The issue was as per the attached image. I could not find the setting until a quick spark reminded me it was all in the string. Subgraph_SmoothingMA.LineLabel = LL_DISPLAY_NAME | LL_NAME_ALIGN_RIGHT | LL_DISPLAY_VALUE | LL_VALUE_ALIGN_VALUES_SCALE; All sorted. Many thanks. Great product and great support. |
