Date/Time: Fri, 23 Oct 2026 02:15:12 +0000
Compatibility with Windows 11 ARM (NVIDIA RTX Spark)
View Count: 520
[2026-07-18 14:01:22]
marctrader2 - Posts: 1
I am considering purchasing one of the upcoming NVIDIA RTX Spark laptops, which will run Windows 11 on ARM. Before making that investment, I would like to understand Sierra Chart's level of compatibility with this platform.
I have a few questions:
Has Sierra Chart been tested on Windows 11 ARM systems (Snapdragon X or NVIDIA RTX Spark)?
Does the current x64 version run correctly under Microsoft's Prism x64 emulation?
Are there any known issues with:
- Denali Data Feed
- Teton Order Routing
- Rithmic
- CQG
- Interactive Brokers
- ACSIL custom studies
- Third-party DLLs
Are there any plans to release a native ARM64 version of Sierra Chart?
From your perspective, would Windows on ARM currently be suitable for professional futures trading, or do you recommend remaining on traditional x86-64 hardware?
My primary concern is long-term platform compatibility rather than raw performance. Sierra Chart itself is very efficient, so I am mainly interested in compatibility with the operating system, routing services, data feeds, and custom studies.
Thank you for your time.
[2026-07-19 22:15:25]
Sierra_Chart Engineering - Posts: 25248
Sierra Chart does support ARM processors.
Yes this is already available:
When you install Sierra Chart, there are two executables provided. One for X64 and one for ARM64.
Not by us but other users can comment on this.
The only potential problem will be with :
- Third-party DLLs
Date Time Of Last Edit: 2026-07-19 22:17:30
[2026-07-21 14:33:05]
ForgivingComputers.com - Posts: 1244
Yes. I have tested both the ARM version and the x64 version on the Mac M4 Mini and have not had any issues. However, I have not used either for live trading, as my main system is an Intel box.
As was mentioned already, if you have a custom study that is not part of the standard build, then it will run under Prism, but not on ARM, unless the developer builds an ARM version.
