Date/Time: Sat, 17 Oct 2026 00:25:01 +0000
Chart window colour split
View Count: 186
| [2026-07-16 07:04:13] |
| Dave - Posts: 9 |
Hello, I have a chart which is split into the first quarter/right edge where the current bar is being created which the background is coloured grey and the historical bars the background is white — I want to change the background of the historical bars from white to something a bit darker. I have tried searching to change that background only but I can only find how to change the right edge quarter. |
| [2026-07-16 14:42:36] |
| John - SC Support - Posts: 48239 |
We do not know how you have your chart setup in order to get the different coloring, so we can not say for certain what you need to do. The coloring for the background in a chart is controlled through the following setting: Graphics Settings: Chart Background If that does not do what you want, then make sure you are changing the correct coloring option - Global versus Chart. And it could also be a study that is coloring, so you would need to check your studies to see if one of them is setup to do this and change the color in the study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
