Date/Time: Mon, 09 Nov 2026 10:55:58 +0000
My CQG
View Count: 189
| [2026-07-13 23:37:51] |
| DOREL STANCIU - Posts: 9 |
Where can I check my CQG?
| [2026-07-14 04:27:32] |
| Sierra_Chart Engineering - Posts: 25406 |
Not sure we understand the question. Sierra Chart does support CQG. Here are the setup instructions: CQG Trading Platform Service If you are only trading the CME Group of markets we recommend using Teton order routing instead of CQG: Sierra Chart Teton Futures Order Routing You will save money and have a better level of service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
