Date/Time: Sat, 31 Oct 2026 18:47:09 +0000
Spreadsheet conversion fails
View Count: 1387
[2014-11-03 10:02:31]
gfs117 - Posts: 24
I'm trying out the New spreadsheet version of SC, but the spreadsheet conversion program (SpreadsheetFileConverter.exe) crashes every time SC tries to launch it. In the Message log it says this:
Launching E:\SierraChart-newSS\SpreadsheetFileConverter.exe with parameters: "E:\SierraChart-newSS\Data\Book1.scwbf" "Book1.scss" 132786 -culture=1033 | 2014-11-03 10:53:21
Conversion process closed without indicating success. Exit code: 3762504530. | 2014-11-03 10:53:24 *
Unable to open E:\SierraChart-newSS\Data\Book1.scwbf because the spreadsheet file conversion failed. | 2014-11-03 10:53:24 *
In the Windows logs, the program generates a "Event 1000, application error"
Naam van toepassing met fout: SpreadsheetFileConverter.exe, versie: 1.0.0.1, tijdstempel: 0x54554830
Naam van module met fout: KERNELBASE.dll, versie: 6.1.7601.18409, tijdstempel: 0x53159a86
Uitzonderingscode: 0xe0434352
Foutoffset: 0x0000c42d
Id van proces met fout: 0x87c
Starttijd van toepassing met fout: 0x01cff74c005802b2
Pad naar toepassing met fout: E:\SierraChart-newSS\SpreadsheetFileConverter.exe
Pad naar module met fout: C:\Windows\syswow64\KERNELBASE.dll
Rapport-id: 3f307af5-633f-11e4-80c7-002522a54891
I'm using a fresh installation of the Dutch version of Windows 7 (64bit). I've tried it with both SC versions 1205 and 1208. The results are the same.
[2014-11-03 20:04:43]
We will look into this. But you may have to manually create a spreadsheet when using the version of Sierra Chart with New Spreadsheets.
