Date/Time: Sat, 07 Nov 2026 13:23:45 +0000
SierraChart Installer
View Count: 254
[2026-07-13 15:59:15]
User359273 - Posts: 31
always show MD5 for file does not match
Received file size:7777544
Recerved file size:6148048
[2026-07-13 16:34:54]
John - SC Support - Posts: 48459
The solution is to use the Zip Installer. Refer to the following:
Software Download: Sierra Chart Zip Installer
Typically, we only see this when Sierra Chart is being used on an emulator. We are curious if this is your case, or if you are running a native Windows computer.
