Date/Time: Sun, 18 Oct 2026 18:39:19 +0000
Backtesting Mistakes
View Count: 1193
| [2014-11-03 09:27:47] |
| User60891 - Posts: 7 |
Hello, I'm testing my automated system using "Auto Trade System Replay Backtest", after that i'm analyzing results in "Trade Activity Log". I notices that if i change "Date Rang to Display" results are incorrect. For example i have results for last 300 days and after that i change period to 30 days inside these 300 days, so i get incorrect results , whole statistics are incorrect, even trades are incorrect. Do you know about this problem? Or maybe i did anything wrong? |
| [2014-11-03 09:31:55] |
We need a simple example of what you are referring to. Otherwise this is impossible for us to comment on.
