Date/Time: Mon, 09 Nov 2026 12:29:15 +0000
NQ Friday 7/10/2026 10:32:41 - SC not showing chart price during huge selloff
View Count: 374
| [2026-07-11 20:43:17] |
| n8trading - Posts: 87 |
On Friday, NQ had a huge reaction to some news that caused the market to drop very quickly. SC didn't show price movement for several seconds and/or was showing spurts of market data with multi-second gaps instead of the usual constant stream. I can replicate this in replay from a duplicated chart with all studies removed and it happens with OS timers and SC timers. Is there any SC configuration that can handle this, or is this a shortcoming of SC that might be able to be improved, or is this a limitation on the exchange/market infrastructure side and nothing can be done about it? Thank you, |
| [2026-07-11 21:00:55] |
| Sierra_Chart Engineering - Posts: 25406 |
Are you referring to 10:30 AM Eastern time July 10, 2026? We replayed that part and there are no issues. Replay is extremely fast and stable. If you are having a problem during a replay, then you need to reduce the CPU usage in the chart. You should go through a process of elimination just by opening only one single chart for NQ without any studies and do a replay and see if you can reproduce the problem. If so, then this is going to be a system specific issue. Also re-download the data for that timeframe in case there is any missing data. Instructions: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-12 00:29:10] |
At 10:32:41 on Friday 7/10 on NQ. It was a huge influx of volume and the market sold off a couple hundred points or so in seconds. If you have the time and wouldn't mind, could you record a video of SC on this chart during this time frame (maybe a 1 to 2 minute) video? And I will try your suggestion as soon as I can. |
| [2026-07-12 03:32:20] |
We had a look more closely at this. We were testing under an accelerated replay previously. There were several interruptions in time which you can see, if you set the chart to a one second interval, but that is from the exchange. Most likely due to velocity logic being implemented. So there is nothing wrong. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-12 03:32:35
| [2026-07-12 04:34:13] |
That's what I was hoping to hear. Thank you.
