Date/Time: Sat, 07 Nov 2026 19:03:41 +0000
Price on Y Axis
View Count: 288
| [2026-07-10 14:20:17] |
| User841161 - Posts: 357 |
I am trying to find where to off the market price from showing up on y axis. There used to be an enable box you could uncheck to disable in the graphics section. But since new version I don't see that option any more.
| [2026-07-10 14:49:46] |
| Tony - Posts: 732 |
Chart -> Chart Settings: Scale: Hide Value Scale: Yes |
| [2026-07-10 15:21:36] |
| Sierra_Chart Engineering - Posts: 25400 |
No that is not the right setting. What you need is: Global Settings >> Graphics Settings - Colors >> Chart >> Last Trade Price Box. There is an Enable column. Make sure the Graphics Settings window is wide enough to see it. You will want to set that to No at that row. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-10 15:23:18
