Date/Time: Wed, 14 Oct 2026 00:57:40 +0000
Need help converting an old Chartbook
View Count: 295
| [2026-07-09 23:47:40] |
| Sivle - Posts: 86 |
Hi everyone, I have an old Sierra Chart chartbook (a .cht file) from a few years ago that I need to open, but the platform won't let me open it directly anymore. I know it needs to be converted to the current modern format. I remember doing this exact process a few years back, but for the life of me, I can't remember the steps anymore. Could anyone give me a quick step-by-step guide on how to properly convert an old chartbook so it can be opened in the latest version of Sierra Chart? Do I need to enable a specific setting under General Settings, or is there another way to force the conversion? Any help or a quick walkthrough would be greatly appreciated! Thanks in advance. |
| [2026-07-10 17:29:50] |
| John - SC Support - Posts: 48196 |
The instructions to do this are here: Chartbooks (Workspaces): Opening Older Chartbooks But, those instructions were setup when we first made a change to the Chartbook format several years ago. At this point, if you are having a problem with a chartbook, then the chances are that the chartbook is not working due to the changes, but probably is corrupted for some reason - in which case you will not be able to open it at all. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
