Date/Time: Sun, 11 Oct 2026 00:03:46 +0000
Moving Sierra from Parallels VM to a VPS
View Count: 243
[2026-07-09 19:31:16]
User558380 - Posts: 61
Hi John,
I want to move Sierra from Parallels VM on my MAC to a VPS. Everything I'm reading says not to move Sierra chart itself but to first download a new version of Sierra on my VPS and then just move my data files over. Does that make sense to you and will I be able to download another version of Sierra? Thanks much.
[2026-07-09 19:50:52]
John - SC Support - Posts: 48169
You can do it either way. The instructions to move Sierra Chart from one system to another are at the following link:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
There are a few options given at the above link, so use whichever works best for you.
