Date/Time: Sun, 18 Oct 2026 18:38:49 +0000
Error with running of two SC copies in same time
View Count: 1225
[2014-11-03 05:47:06]
User60651 - Posts: 6
Hello.
I`ve read earlier, that users of SC may use 2 copies of SC on 2 separate computers in the same time. But when I`m trying to execute SC on the second PC with my login, SC on the first PC writes me this in log: CTS FIX: Received a Logout message. Text = Your username and application have logged in another instance (either on the same machine or a different machine) and this api instance has been disconnected | 2014-11-03 11:20:51 . I`d like to have an opportunity to run CS on another PC to allow my friend to access to SC in demo mode in the same time, when I`m using SC in the real trading mode. Thanks.
[2014-11-03 06:41:07]
There is no limitation was Sierra Chart with this.
This is a CTS limitation which they are required to do based on exchange rules:
http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#RulesConcurrentUsePrograms
[2014-11-03 11:55:00]
OK, thank you. I`ll try contact with CTS about this.
