Date/Time: Wed, 14 Oct 2026 01:01:10 +0000
Anpassung Contract working orders
View Count: 228
[2026-07-09 14:07:21]
User437588 - Posts: 92
Unfortunately, I seem to have changed a setting regarding my orders.
Previously, when I took partial profits, I could adjust the existing order by clicking on the contract count and entering a new value. Unfortunately, that no longer works.
Please see the chart. Which function needs to be enabled to make this work again?
Thanks for your help.
image2026-07-09_16-02-18.jpg / V - Attached On 2026-07-09 14:07:16 UTC - Size: 220.28 KB - 114 views
[2026-07-09 15:37:00]
John - SC Support - Posts: 48196
When you move your pointer over the Quantity section of the working order, does that square that contains the quantity change color slightly (get "brighter")?
[2026-07-09 21:59:21]
Sierra_Chart Engineering - Posts: 25165
When you try to modify the quantity of the order, check to see if there is any rejection shown in Trade >> Trade Service Log.
The other question is if do you notice the same problem when using Trade Simulation Mode:
Trade Simulation
