Date/Time: Sun, 11 Oct 2026 00:02:33 +0000
Mutliple connections to TETON (2 SC instances)?
View Count: 234
| [2026-07-09 12:56:47] |
| tomas262 - Posts: 164 |
Hello, I have 2 AMP accounts it this possible to have 2 SC instances (difference PC locations) to connect using same TETON login and each instance trades different account? I have Denali and exch fee enabled for 2 PCs. Date Time Of Last Edit: 2026-07-09 12:56:57
| [2026-07-09 13:05:50] |
I am testing it not trading yet but it seems to be OK
| [2026-07-09 14:36:16] |
Had the 2nd instance connected for a while, then disconnected the 1st instance and had a problem reconnecting it for some reason I switched data provider to CQG for the 1st instance and reverted back to TETON. Closed the 2nd instance and tried to reconnect the 1st. It works again So not sure now whether it is fully supported Date Time Of Last Edit: 2026-07-09 14:36:34
| [2026-07-09 15:51:51] |
| John - SC Support - Posts: 48169 |
There is no issue with having multiple Sierra Chart installations accessing the same Teton accounts at the same time. The main thing that could be a problem is that the exchanges require a second set of fees for connecting from two different computers at the same time. But we see that you already have that option set to "2 Systems", so you would not have an issue with the data. We wonder if you may have been seeing the issue we had with some data earlier today. Refer to the following: Notice: July 9, 2026 - Internet Connectivity Issues Affecting CME Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
