Date/Time: Mon, 23 Nov 2026 05:16:13 +0000
[FEATURE REQUEST] New 'Number Bars Cal Values 2' SG
View Count: 460
| [2026-07-08 17:43:30] |
| Brookwood - Posts: 45 |
I would like to have a new SG line added to the 'Number Bars Calculated Values 2' study: the summary info from the chart DOM 'Current Traded Diagonal Ask-Bid Volume column. I cobbled together a text display from the Sum Bid/ Sum Ask SGs and would like to be able to do the same with the diagonal data. Thanks in advance Date Time Of Last Edit: 2026-07-08 17:45:12
| [2026-07-08 18:04:26] |
| John - SC Support - Posts: 48610 |
We want to make sure we are understanding what you are wanting. We believe you are saying that you want the sum of the values displayed in the "Current Traded Diagonal Ask Volume Bid Volume Difference" available in the "Numbers Bars Calculated Values 2" study. Please verify that this is correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-08 19:50:32] |
Correct.
| [2026-07-08 19:55:18] |
We have noted this as a Feature Request.
| [2026-07-13 21:45:41] |
| Sierra_Chart Engineering - Posts: 25463 |
This we cannot provide. There is not a reliable way to utilize, the Chart DOM column data in the Numbers Bars Calculated Values study. We just simply are not going to do this and have an unreliable implementation. The two are very unrelated to each other. What we can instead do and we have to see if this is already available, is provide a sum of the Diagonal Ask Volume minus Bid Volume values per chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-14 21:57:39] |
The goal of my request is to be able to have that info available as a 'Text Display for Study' study. Currently I use the Pulling/ Stacking info taken from the 'Number Bars Calculated Values 2' study together with the 'Study Subgraphs Subtract/Difference' and 'Text Display' to create an easily visualized Head-Up Display sum of this info. So it doesn't necessarily have to be in the 'CV2' study-- I'd just like to have the info ported out somehow to I can see it conveniently as text if that is possible technically. Appreciate you looking into this in any case. Diagonals on the DOM was a really nice addition. |
| [2026-08-14 07:27:37] |
This has been added to the Numbers Bars Calculated Values study: What we can instead do and we have to see if this is already available, is provide a sum of the Diagonal Ask Volume minus Bid Volume values per chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-08-14 07:28:36
