Date/Time: Sun, 18 Oct 2026 18:38:49 +0000
Chart not updating tonight
View Count: 1290
| [2014-11-02 23:52:51] |
| TGuth1 - Posts: 6 |
Box is checked for load weekend data. I can get new data by disconnecting and reconnecting but it does not update in real time. Infinity AT DOM is working fine
| [2014-11-03 06:55:16] |
Refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html If you need further help we recommend contacting TransAct support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
